HELP! I just purchased a new LG Flatron 795FT Plus recently and I am using Win 98 SE with Intel 815 Intergrated Graphic Controller.
There was a problem regarding screen display. No matter which resolution I switch to (from 640x480 to 1280x1024), I notice that there are some kind of 'wave' pattern appeared on the screen. The 'wave' was stayed on the same spot and was not flickering nor moving. I kept my speaker and CPU far from the monitor, used voltage regulator, but the problem still remain.
By the way, I found that the screen display is a little concave. Is it normal?
What's wrong with my monitor? Any solution?
Thanks and hope to hear from you ASAP.
