Lexus GS350 (470bhp) GT and LS500 (600bhp!!!)
JYDog
290
The high torque from batteries is probably why it has such a high MPG(city). You see on cars that gets displacement increases, the mileage gets better as a effect of the extra torque.
Aug 16, 2001
22,510
9
Originally posted by: SuperTool
HP is torque*rpm. what's the torque curve for electric motor at higher rpm?
The electric motor has the same torque in the whole rpm range (with some small variations). That's what makes them so cool.
Feb 10, 2000
30,029
67
True true. This is why I think hybrid technology does potentially make a lot of sense for a performance car. I believe, and hope, we are still in the infancy of the use of hybrid drivetrains. Even if mileage is not a primary focus, I always prefer designs with elegant engineering, and I love a lot of aspects of the ways hybrids conserve power.
ElFenix
102,407
8,595
false!
Goosemaster
48,775
Originally posted by: Eli
Originally posted by: Skoorb
Originally posted by: maziwanka
can you just add hp between electric motor and the regular motor like that? what kind of performance should we expect these cars to have?
You could if the torque for the gas engine was at very low RPM, since electrics are very torquey at low speeds themselves, but I'm sure that with gearing you could deliver their torque wherever you wanted.
I still call shens on a car making 60 mpg with that number of horses.
eh.. I think you're all thinking about it too hard.
HP is torque.
They add the HP of the electric motor together with the HP of the engine together currently, so what's the difference? They're just going to be using higher performance versions of each. :D
I, too, question the 60mpg figures though... :Q We'll see.
THink of it as an on demand supercharger.
IF the car were to use gasoline fuel to power the electric motor, as is common today, as indirect as it may bethere would be a decrease in MPG> WHat I believe they are doing is using wasted energy already available. FOr example, breaking has a great deal of potential in the convservation of energy in the automkotive system.
THe main difference between these hybrids and the prius, is that Prius type hybrids are used only to increase MPG. If these EM's can be activated at higher RPM's via a myriad of extra gears and such, the conserved energy via braking + a coil will mean "free turbo power" as it will not use up anyu more gass.
It is all about keeping energy in the system. Not only will THis save gas like hybrids due today, but it will also take advantage of large amount of energy wasted in the current implementation.
Braking a 2000-3000+ lb car from 60mph is a LOT of free energy:D
Kudos to toyota for being smart©
Goosemaster
48,775
false!
Therefore they have to add an addtitional set of gears coupled with a powerful EM to have it spinning slowly at all times:D
Wow, after reading this thread I now see how fvcking clueless most of you are.
Eli
Super Moderator | Elite Member
8
Imagine if they hooked the motor to a CVT and then through the normal transmission gears.
:D
IshmaelLeaver
1,519
There is no way both motors will be applying all of their resources to the drivetrain at the same time. Maybe it could be modded to do so, but it's not going to come from the factory like that.
Eli
8
false!
While his wording is indeed false, the overall point he was trying to make is that a DC electric motor makes peak torque at 0RPM, which is quite different from the torque curve of an internal combustion engine.
Eli
8
Obviously not.
Is that 60MPG figure supposed to be combined, or city, or highway, or what?
Anyway.. Maybe the electric motor handles say 0-45 and the engine kicks in for highway speeds?
Who knows..
Eli
8
Originally posted by: z0mb13
how can they simply add the two HPs together??
If you somehow had a car with 2 engines.. say, one for each set of wheels.. to accurately represent the power present, you would add the power of both of them together.....
no?
:p
IshmaelLeaver
1,519
no?
:p
Only if one motor powered the left wheels and the other powered the right.
D
Deleted member 4644
no?
:p
Wouldn't it depend largely on how the gearing is setup?
Howard
47,986
11
:D
Why use gears when you've already "geared" the torque output?
Anyways, not many CVTs can handle that much torque.
Goosemaster
48,775
Even so, you let me speak knowing this:D
Please educate me on the truth the. I actually want to know the details of how this thing will be implemented.
Also, even if I was wrong, that was what I want it to be...:D ...
Honestly Ive had too many beers to get into it.
Basically, the electric motors start the car from motion with an amazing amount of torque, as their torque/power curve dies off and passes its peak power the combustion motor kicks in and takes over producing the power for the awd system.
ElFenix
102,407
8,595
false!
i don't know how you could get that intent from those words
thomsbrain
18,148
regarding the gas mileage, it's not that surprising, and here's why:
keep in mind that with the electric motor putting out 170-200 HP on it's own (and max torque at zero RPM), you'll never touch the gas motor during leisurely driving except to charge batteries. the only time the engine will have to be involved in moving the car is when you really let it rip. it's not like the prius where the electric is so puny that you have to have the gas going except in parking lots. 200 HP is plenty to move even a large sedan at freeway speeds. the gas motor will mostly work as a generator except for when you're tearing Corvettes new buttholes.
OS
15,581
false!
Yeah serious, this is a supercommon misconception among casual car enthusiasts. How much torque an electric motor puts out depends on many different factors, AC/DC power, winding/armature type, induction type, blah blah. I had a class on electric machinery and there are a lot of considerations and quite frankly I don't remember seeing ANY electric motor with a completely flat torque output and I saw many, many torque graphs for a variety of electric motors.
In fact, if you take his statement of;
"The electric motor has the same torque in the whole rpm range (with some small variations)."
You can apply that to almost any modern, semi respectable gasoline engine. example, accord v6 dyno
