Let's talk about tire psi - Inflating to sidewall
Status
Not open for further replies.
JulesMaximus
74,586
986
Text
Michelin's Recommendations on Tire PSI
Check Pressure Once a Month
?It?s possible for a passenger tire initially inflated to 35 psi (pounds per square inch) to lose 1 psi each month.
?Be sure to properly check all four tires ?cold? once a month and before a long trip.
?Whether you have a full-size or mini spare, make sure that it is properly inflated as well.
.Recommended Pressure
If you don?t know the proper inflation air pressure for your tires, what do you do?
Easy. Check at one of the following places on your vehicle:
?In the vehicle owners manual.
?On the vehicle?s door jamb. (Often, a vehicle information placard is located on the door jamb along with the recommended tire inflation pressure.)
?Inside the fuel hatch filler flap. (In some vehicles.)
?The glove compartment door. (In some vehicles.)
?But NOT on the tire. The inflation pressure shown on the tire sidewall is only the maximum tire inflation pressure. In most situations, the vehicle manufacturers recommended tire inflation pressure is shown on the vehicle placard. However, on some older vehicles, the recommended pressure listed by your vehicle?s manufacturer may be shown as two numbers: One for city speed driving and normal load and one for highway speeds and/or maximum capacity vehicle load. Be sure to inflate your tires to the recommended inflation pressure for each type of driving situation.
How to Properly Check Tire Pressure
1.Beware of public pressure gauges at gas stations. They are often abused and unreliable.
2.Purchase a good pressure gauge and check it for accuracy with your Michelin retailer.
3.Check your tires ?cold? ? before you?ve driven even one mile or at least three hours after the vehicle has been stopped.
Inflation Tips
1.Air expands when it?s hot and contracts when it?s cold
2.It?s best to inflate your tires in the morning before the day?s heat.
Valves and Valve Caps
When it comes to proper tire pressure, the tire?s valve is a very important maintenance item. Valves are ordinarily made of rubber, so they can deteriorate over time. Replace them when you buy new tires. At high speeds, a cracked, deteriorated rubber valve stem can bend from centrifugal force and allow air loss.
The valve cap is also an important item. Buy high-quality valve caps that can help contain the tire?s air, should the core of the valve fail for any reason. Valve caps also keep out moisture, which could freeze and in turn depress the valve core, causing air loss. The cap also keeps out dust and dirt particles, which could also interfere with the proper operation of the valve core and cause air loss.
Does Michelin say, "listen to fleabag" anywhere in there? Case closed.
\thread
jlee
48,518
223
Originally posted by: JulesMaximus
I suggest listening to the people who actually make tires and have decades of experience with the latest technologies, millions of miles of racing experience, and trillions of miles of actual on road experience over a complete stranger, a child in fact, on the internet.
Anyone figure out yet how it is that he's smarter than Hyundai's automotive engineers, but can't figure out how to post in the right forum?
MrMatt
Banned
Mar 3, 2009
3,905
7
question then: what's the best PSI to have your tires at, for gas mileage, if they recommend 32?
lxskllr
60,322
10,738
The best for gas mileage is max. Less than that gives better traction, and a softer ride.
SuperSix
You people that inflate to the sidewall max need to DIAF and stay the fuck off the roads my family and I are on.
This has got to be a joke thread . . . .
lxskllr
60,322
10,738
WTH are you talking about?
mb
10,233
Intentionally over-inflating your tires with the knowledge that it decreases traction (and thus safety in some situations) is pretty fucking stupid and selfish.
waffleironhead
7,069
572
no, it is not a joke.
the op has also stated that he wont buy a car with a sunroof because the extra weight would ruin his gas mileage.
jlee
48,518
223
You've got to get the best mileage possible so you can afford to pay $32/tire for mounting and balancing!
JulesMaximus
74,586
986
Oh, he goes beyond that even. He has stated that he inflates to beyond the maximum sidewall rating.
lxskllr
60,322
10,738
You're not overinflating if your at max or less. The car manufacturers specify a lower than max inflation for the softer ride, that's it. I've put more miles on the road than probably everybody in this thread. From cruising at 90mph, to driving on cobbles in the city, to creating trails through the woods, and I've had 0 problems with my traction....
JulesMaximus
74,586
986
And how many miles would that be?
fleabag
Banned
Oct 1, 2007
2,450
Well shit, why don't we just murder all those people who buy LRR tires! :roll:
InflatableBuddha
7,416
Originally posted by: SunnyD
Originally posted by: fleabag
Originally posted by: BeauJangles
So after getting owned in the garage forum, you bring this argument to OT?
http://forums.anandtech.com/me...id=85&threadid=2345466
Thread called on account of stupid.
Zenmervolt - AnandTech Garage Moderator
I thought I was posting in the garage but it's ok because I do benefit from having a different audience to post to.
Except that crossposting is against forums rules.
:laugh:
And motion for BAN.
lxskllr
60,322
10,738
Easily over 1,000,000
For quite a few years I was driving over 50,000 miles per year. I haven't been lately, but I've driven a ton on everything from a VW bug to 1 ton pickups and vans(currently a Jeep Cherokee)
SuperSix
Incredibly ignorant statement.
It has nothing to do with a "softer ride" it's for the best, most efficient tire cotact patch, promoting the best stopping distances and overall traction, and for the best wear/longest tire life.
This thread + the one asking if guys change tires has greatly reduced the testosterone that once ruled these forums.
The pussification of Amerikka continues.
I have to give it to the OP - he is a master troll. :D
lxskllr
60,322
10,738
No it isn't. Put up, or shut up. What are your qualifications? I posted mine...
lokiju
18,526
Other reason.
I have pressure sensors in my Forester and inflate them to manufacture spec so I don't have to get a warning light on my dash all the time.
seepy83
2,132
That's crazy talk. I can feel a difference in traction/handling/steering/etc from being 5 psi under my manufacturers recommendation, and being at their recommended pressure. I have a very hard time believing that I wouldn't notice any difference if I went another 5, 10, 15, 20, etc PSI up.
lxskllr
60,322
10,738
The tire's rating trumps the manufacturers rating. What if you put light truck tires on your vehicle? Typical max for a passenger tire is 35psi. Typical max for a light truck tire is >60psi. If you inflate that 60psi tire to the manufacturers 35, it has a good chance of peeling apart after driving awhile, especially at highway speeds.; I've seen it happen....
Mike Gayner
6,175
I put air in my girlfriends tires a couple of weeks ago - that poor neglected car's tires were at 9 psi :eek:
fleabag
Banned
Oct 1, 2007
2,450
Unfortunately, common sense and logic need not apply to these people. They'd rather have their tires get frayed and blow out prematurely than dare go against what the car manufacturer recommends. If these people were up on a canyon road and there was a sign that said turn right but there is no where to turn right on to, they'd turn right anyway and would promptly fall of the road.
Capt Caveman
34,543
651
Wow. It also affects handling and traction. Simple physics would point that out.
jlee
48,518
223
Funny, my BF Goodrich All Terrains were fine for years at 33psi front / 28psi rear. Any more than that in the back and I was riding on the middle of the tire.
Your idiocy is astounding.
Status
