K1052
- Aug 21, 2003
- 48,095
- 37,307
- 136
The ones who benefit from CA water aren't the farmers or citizens, it's the billionaires...like the Reznicks.
Distribution of said benefits of course is unlikely to be equitable.
Pumping water hundreds of miles sounds like an extremely energy intensive process when you factor in distance and elevation differences.
Oil pipelines seem to be able to do it.
Israel gets most of its potable water from desal. I think it's inevitable that the U.S. southwest (mainly California) will have significant desalination plants.Desalinization is very expensive, otherwise we already would be doing this all over the place.
DIAF, says this Oregonian.Water from the Columbia River. There is enough water to irrigate the entire western US.
1) Why pipe water from the Pacific, up to Lake Mead, only to turn around and aqueduct it back down to Southern California? (25% of the water usage from Lake Mead goes to California I believe, simply backing that demand out would leave surplus in Lake Mead). So don't need massive pipelines all the way up to Lake Mead.Sounds crazy doesn't it. Lake Mead is the largest capacity water reservoir in the United States and serves water to the states of Arizona, California, and Nevada, as well as some of Mexico, providing sustenance to nearly 20 million people and large areas of farmland At just under 300 miles from the Pacific Ocean a pipeline is certainly feasible when you consider that the Colonial Pipeline for oil consisting of two tubes extends between Texas and New York and can deliver 3 million barrels of fuel per day.
So why haven't we already done this? It's not oil, and no one is going to line politician's pockets to get a water pipeline.
2) Cost, cost, cost. Users currently get water for basically free. Desalination costs roughly $2000/acre-foot for water. Southern California agricultural users pay <$100/acre-foot on average. And ~80% of the usage is agricultural...
So investing in large desalination plants to produce fresh water at $2000/acre-foot, in order to resell it at less than $100/acre-foot, for some odd reason hasn't found many interested investors. Although there has been some investment by forward looking municipalities that don't have to make a return on investment - and can force the cost increases along to their customers.
"Simply" put a much higher real price on the water for all users, and the market will adjust, at a fraction of the cost of large scale public works desalination.
Especially if they then export those products. Free-marketers will scream but if you wake water from the central valley to grow almonds by the bushel and then ship them the fuck overseas, you can fuck right off.Well yes, I also would not let CA valley farmers empty all the aquifers for their water intensive export crops but clearly that's not going to happen either. The rural west will be F'd sooner or later for good once there is literally nothing else to take. The cities will be ok because they can afford things.
much of the time oil pipelines use gravity and pressure from the compressor stations in the oil fields that are powered by the oil or nat gas itself. along the way they use some of that to also power monitoring equipment using external combustion and thermoelectric generators (tecs) they are also often going down in net elevation over long distances to the coast for export or refining.Oil pipelines seem to be able to do it.
And also says this Washingtonian.
And this Warshingtonian sez "Fuck the fuck off."
Also, as mentioned in the OP, at least SOME of the water from the Colorado ends up in Mexico. Why should the USA over-pay to treat water that going to end up in Mexico?
We already do. We built a very expensive desalinization plant to treat irrigation return water from a subsidized irrigation district so that welfare farmers could continue to grow cattle feed and spectacularly subsidized* cotton in the desert.And this Warshingtonian sez "Fuck the fuck off."
The US “only” pumped $46 billion in direct payments to US farmers in 2020. With the substantial majority going to less than 100k farms.*US cotton subsidies are so bad, the Brazilian government filed a complaint against the US with the WTO. Rather than scale back the handouts to US cotton farmers, the US settled the complaint by agreeing to subsidize Brazilian cotton farmers as well.![]()
Perhaps in the minds of those that depend on the racial bogeyman to be the cause behind all their problems, but in reality rivers and access to their waters is a problem that occurs in many other places irrespective of any CRT nonsense.It ALL used to go to Mexico.
Also, most of the Colorado River watershed used to BE Mexico.
Oh, shit; did I just teach CRT?
Solar and wind power can provide power for pumps, Romans 2000 years ago had aqueducts no reason with today's technology that a similar national project couldn't be done in the USA, after all didn't we throw away trillions in Iraq and Afghanistan.much of the time oil pipelines use gravity and pressure from the compressor stations in the oil fields that are powered by the oil or nat gas itself. along the way they use some of that to also power monitoring equipment using external combustion and thermoelectric generators (tecs) they are also often going down in net elevation over long distances to the coast for export or refining.
www.forbes.com
No they didn't. The Salton Sea was an accident that happened while they were building canals to manage Colorado River waterand people thought the Salton Sea was a good idea.
en.wikipedia.org
