Originally posted by: vtqanh
Originally posted by: pnho
i just think they are polycarbonates? usually retail chains sell these as their ultra light, ultra thin lenses. I would recommend High Index 1.66 aspherics for thin and excellent optics compared to other lenses. Anti-reflective should be included and "hardness/scratch coating" are kind of a scam. Another note on polycarbs, they are great for safety glasses however, the optics are terrible and the distortion on them can cause headaches when you aren't used to them. Just remember the thinner the lens, the higher the price. I believe they have a High Index 1.71 out on the market, just at an extremely high price. If your prescription is greater then +/-3.00 then I would recommend HI 1.66.
To make ur lenses look thinner, I would recommend smaller frames, because the center cut on lenses are thinner compared to outer edges.
hope that helps.
Scratch coating is not a scam. The polycarbonate is extremely vulnerable to scratches. Without the scractch-resistant coating, you won't recognize your lenses after one month.
Smaller frames do not make your lenses look thinner in all cases. If you have a minus prescription, then smaller frames mean thinner lenses. If you have a plus prescription, then smaller frames mean thicker lenses
And there is not much difference between featherweight and featherweight plus. They both have the same center thickness. The featherweight plus looks thinner because the lenses are of flatter base. And featherweight plus also looks better because of their flatter base. The coating on featherweight plus is also better than the coating on regular featherweight. This does not apply all the time, if you have a high prescription, the lab has to surface it, and if they have to surface it, then both will come out with the same coating on the back.
What kind of high-index are you wearing? If it's 1.555 high-index then it's not much thinner than featherweight since featherweight's index is ~1.5.
If your prescription is high, order hi-index 1.67. It will be thinner.
