L lesch2k Golden Member Feb 15, 2001 1,159 0 71 Mar 10, 2007 #1 i need help with a level where the wolf needs to pass over the bridge that catches on fire. how do you get past that thing. i've tried moving the blocks but that doesnt really go anywhere. thanks. try to keep the spoilers out of this thanks.
F FP Diamond Member Feb 24, 2005 4,568 0 0 Mar 10, 2007 #2 Forget about getting across. Just jump off the bridge.
L lesch2k Golden Member Feb 15, 2001 1,159 0 71 Mar 10, 2007 #3 thanks, but i cant figure that out either... where do you jump?
F Furyline Golden Member Nov 1, 2001 1,212 0 0 Mar 10, 2007 #4 Originally posted by: lesch2k thanks, but i cant figure that out either... where do you jump? Click to expand... Think you need to climb onto a box
DanTMWTMP Lifer Oct 7, 2001 15,908 19 81 Mar 10, 2007 #5 move that box to the edge..climb on in..move onto edge. jump down
F FP Diamond Member Feb 24, 2005 4,568 0 0 Mar 11, 2007 #6 I just hopped up onto a box, walked over to the edge and jumped off.
