Jeff7
- Jan 4, 2001
- 41,596
- 20
- 81
This.http://michaelbluejay.com/electricity/cooling.html<thermodynamics and heat transfer stuff>
Because science. That's why.
Arguing against that is like arguing against the value of insulation.
I like this way of putting it. ^But if the AC is on when you're gone, then you've turned your house into a heat magnet. [By] keeping it artificially cool, there's no limit to the amount of heat it can absorb.
Or put another way, it turns your house into a thermal sink, up to the maximum capacity of the air conditioner, and you're paying for every kWh.
If the house isn't being cooled:
- As it approaches equilibrium with the outside temperature, the rate at which it heats up will decline. Energy will hurry across a resistive barrier (insulation, or a wall) in a big hurry if there's a big difference in temperature. As the difference gets smaller, the energy doesn't cross the barrier as quickly. So minimizing that difference in temperature will slow the energy transfer. That's why it saves energy to run your house cooler in the winter: If you've got it toasty inside, that energy is trying hard to get outside. If you've got it frigid, only 10° above the outdoor temperature, the energy inside isn't going to be trying as hard to get out.
- Once the house reaches equilibrium with the outside, the energy has no motivation to move.
The only other factor then is sunlight, which will warm the house. Fun part: As the inside of the house starts to heat up above the outside air temperature, the excess energy inside will now try to make its way out. So you're now dumping excess energy out of the house for free.
I do set the timer on my AC though, so that it turns on a few hours before I get home. It's got enough BTUs to cope with the summer heat, but since it doesn't have any kind of 100,000 BTU surge capacity
The AC may be a bit undersized for the space it has to cool, but my choice of window unit is limited by:
- 120V lines are available. 240V would require new wiring.
- A large 240V unit probably wouldn't fit in the window.
- My spine would crush itself into something resembling calcium diamonds.
