Captante
First step is getting a ip68 certified device and something with a cellular data connection. You should be aware that it'll only work on the surface though. Water kills signal super quick. Those pool floaters work okay as long as the waves aren't too rough. I've surfed on one at resorts in the carribean
Actually if I'm not mistaken the signal itself actually carries better through water then through air, but your phones antenna can't receive via that medium.
I used to have a problem with early Verizon digital phones when near the shore in CT where the signal from repeaters on Long Island provided a stronger signal from the water then the actual local units did via the air. (per a Verizon tech)
