Zenmervolt
Elite member
- Oct 22, 2000
- 24,514
- 44
- 91
With the wheels spinning the engine, the ECU can (and does) shut off the injectors if the engine is above a certain RPM with the throttle closed. My 1986 car does this. Pretty much every EFI car has done this for decades.Originally posted by: halik
Please do explain how ecu turns off injectors without stalling the engine... I'd really like to know that. What really happens is that you're reving down the engine at closed throttle and low fuel mapping and high rpms. Compared to neutral where the car is at low rpms and low fuel mapping. So you burn X times more gas where X is how many times faster is the crank spinning.
Also braking with engine does put more strain on the drive train, because you're applying the friction force of the road opposite of the rototation of the engine, tranny, drive shafts etc. I prefer to use the intended parts to apply this force - the brakes.
As for strain, far more force is imparted by even casual acceleration than is imparted by engine braking. Coasting down while in gear is no harder on the drivetrain than anything else. F=MA M does not change, so the force on the drivetrain is proportional to acceleration (or deceleration) rate. The rate of change of speed when coasting down in gear is less than the rate of change in speed when accelerating in gear. That means that there is more force imparted on the drivetrain during acceleration than there is while coasting in gear.
ZV
