Jeff7
- Jan 4, 2001
- 41,596
- 20
- 81
HAWT!Originally posted by: BeauJangles
Originally posted by: DrPizza
Chisel away at the crack, apply hydraulic cement. Put fans on the wall to dry. Paint concrete wall with one of those special paints made for sealing out the water. THEN, if you don't succeed (and you probably will), start considering the professionals.
:thumbsup:
I actually just fixed a few cracks using hydraulic cement and the Behr water sealing paint. The can says it can resist up to 10 psi of water. It's white and thick as hell. And it works.
OP, definitely try fixing this yourself before hiring anyone.
:laugh:
Oh, and hydraulic cement might not work if the foundation is still settling. My parents' house is.....phew, I don't know, 40 years old maybe. One of the cracks in the basement wall had been "repaired" at least 3 times before we moved in. Another crack on the other side of the house, which I filled in myself, had formed a hairline crack down the middle only about a month later.
That house's foundation has got to be at least 14 separate pieces now. I think they used pipecleaners instead of steel rebar. (Do residential houses even use rebar in the first place?)
