Lead in tap water - what can I do?
Originally posted by: Mwilding
Originally posted by: Eli
How did you have your water tested?
Bought a testing kit at Home Depot.
You just fill up the tube first thing in the morning with water that has sat in the pipes all night and mail it in with your $15 check. 2 weeks later - voila!
Cool.
Kinda interesting that they would tell you to leave the water sit in the pipes. I guess it should be worst case scenario..
Originally posted by: Pepsi90919
don't worry, i can get your wife pregnant for you, and i don't have lead pipes. everything will be ok. :thumbsup:
My two-headed, three-tailed swimmers are just fine, thank you very much! :|
I didn't know you lived so close to 3 mile island. 😉
FWIW lead poisoning isn't going to affect your fertillity, it will affect your offspring though in a VERY negative manner as I'm sure you are aware.
curious...where did you have the test done??
Also, what type of plumbing do you have in your house (galvanized, copper, PVC...)
I just bought an old house, so I'm curious
Well, I hope GimpyOne is right, but I think SunDogg is for where I live too... 🙁
Just left a message with the water company to see where they stand. Next call - local town government...
Where I live, you own everything from the meter on. You have to locate the source to determine if it's from the house or the water supply. Given you have lead pipes, it's probably coming from the house. However, you would have to take another sample at the meter (or the point where you take responsibiliy for the pipes in your area) and compare the two to figure out which.
Once you have that comparison, you know the source and you can figure out who's responsible. Good luck not becoming retarded. 😛
Becoming? 😉
Cool.
Lead is not in the water supply. It leaches into the water in your pipes either from lead pipes, lead solder on older pipes or brass fixtures (which contain lead). Testing in the morning tells you what the maximum lead level is in your home.
Very incorrect statement, a correct statement would be there is no lead in the water supply in my area. Lead is a contaminant that can very easily be present in the water supply of your local water district, for example lead is a natural contiminant in the water supply locally (Utah) due to mining in the early part of the century. The lead level in the water is actionable by the EPA if it exceeds the threshold value and there is a number to report it to the EPA if it's in the supply system and not a result of your internal plumbing. Just a FYI.
Becoming? 😉
Becoming.
B-E-C-O-M-I-N-G.
v. be·came, (-km) be·come, be·com·ing, be·comes
v. intr.
To grow or come to be: became more knowledgeable; will become clearer in the morning.
Becoming.
http://dictionary.reference.com/search?q=becoming
I'm no english major, I'm sure there is a better way to write that, and if you were right I really wouldn't care so much. That being said... Why the fvck would you correct someone without bothering to check your facts?
Becoming.
B-E-C-O-M-I-N-G.
v. intr.
Becoming.
Nothing like someone flying off the handle when their sarcasm meter is broken. 😛 But for the sarcasm impared I will elaborate, I was implying that Mwilding is already retarded, in a humerous manner of course.
Main Entry: sar·casm
Pronunciation: 'sär-"ka-z&m
Function: noun
Etymology: French or Late Latin; French sarcasme, from Late Latin sarcasmos, from Greek sarkasmos, from sarkazein to tear flesh, bite the lips in rage, sneer, from sark-, sarx flesh; probably akin to Avestan thwar&s- to cut
1 : a sharp and often satirical or ironic utterance designed to cut or give pain <tired of continual sarcasms>
2 a : a mode of satirical wit depending for its effect on bitter, caustic, and often ironic language that is usually directed against an individual b : the use or language of sarcasm <this is no time to indulge in sarcasm>
synonym see WIT
Originally posted by: Beau
Originally posted by: Sundog
Originally posted by: GimpyOne
I would call your city utility company about it initially. For most utilities, anything outside the foundation of your house is their problem not yours, and with levels that high they would be required to do something about it immediately, including probably testing all of the water in the area for lead as well.
Where do you get that from??????😕
Around here it is anything outside of your property line. That includes incoming water and sewer lines.
same here
Here it is anything outside your house.
same here
You all are correct. People who live in a place in suburban California can't understand that in most areas of US, people own LAND around their house and people from rural areas don't understand, Californians rarely own property beyond the foundation that their house sits on.......
same here
No, most people in California do own land around their house. Most homes in California have a front lawn, drive way, and backyard that extend around 15 feet in the front and back of their home.
Originally posted by: Pliablemoose
Reverse osmosis...
I've had one for years, costs about $100/year to keep it running with new filters/membranes.
that take a bite out of your water pressure?
Reverse osmosis...
I don't think it does.
You need to get one with a tank, though. The RO unit filters water until the tank is full. The tank is pressurized.. so you get normal water pressure.
Reverse osmosis...
You won't even notice it.
RO FAQ's
(I get my membranes from the company in the link)
http://www.pwgazette.com/index.html
I plumbed ours into the refrigerator, so the ice tastes good, even the bottom of the ice bin doesn't go stale for a week or so now...
same here
15 feet is nothing. In most areas of US, people own land counted by acres.
good luck on this man, hope you get this fixed quicker some way, or your gonna be going slow, unlike that guy from godfather 2 that got lead the quick way through his mouth. Awesome movie, i wanna watch it again btw.
You need to run two tests. One at the tap where you consume and one nearest the main. The difference between them (assuming the one tap is near the foundation) is what your home plumbing is contributing to the problem.
It MAY be that your incoming water is fine. You should know this in any case.
Just spoke to the water company guy. In 1973 they changed the line from the main to the curb. It is unchanged the rest of the way and is my responsibility. If I wanted to replace that line it will cost $3000 to $5000 🙁. As lead is an "inferior material" it will leak at some point. If I wait until then, it will cost more... :Q
In the meantime, he asserts that if I run the water for 3-5 minutes that my lead levels will return to undetectable. I am going to test this, but there is no reason for him to lie about this. He also suggest redoing as much of the internal plumbing as possible - which is being done - for two reasons: 1. Old galvanized and brass piping is often lead lined and 2. Old fixtures were often lead lined.
One other assertion: NEVER EVER DRINK WATER FROM YOUR HOT WATER TAP!
He's correct about both (hot water, and running the water first).
EPA info.
First two paragraphs are:
Flush Your Pipes Before Drinking
Anytime the water in a particular faucet has not been used for six hours or longer, "flush" your cold-water pipes by running the water until it becomes as cold as it will get. (This could take as little as five to thirty seconds if there has been recent heavy water use such as showering or toilet flushing. Otherwise, it could take two minutes or longer.) The more time water has been sitting in your home's pipes, the more lead it may contain.
Only Use Cold Water for Consumption
Use only water from the cold-water tap for drinking, cooking, and especially for making baby formula. Hot water is likely to contain higher levels of lead.The two actions recommended above are very important to the health of your family. They will probably be effective in reducing lead levels because most of the lead in household water usually comes from the plumbing in your house, not from the local water supply.
