- Jul 30, 2003
- 16
- 0
- 0
hey all,
so i finally decided on an lcd and ordered the hercules prophet 920 pro dvi (i live in the US too, and they had free shipping from the hercules direct store incase anyone is interested).
anyways, it works great except for one thing. there is a patch of light/whiteness at the top of the panel. i do not know if this is normal at all. you can only notice it when the screen is a bit dark but that is quite often when playing games.
To describe how it looks, it looks almost as if there is a thing long light stuck on the very top of the panel causing the top half inch or so to be brighter than everything else.
any thoughts on this? i plan on calling tech support tomorrow (not open today, methinks) but i dont know if i should believe them if they tell me "oh, that's normal."
thanks!
thanks!
