Originally posted by: Philippine Mango
depends, if you got a screen saver goin then I'm sure it should be fine but if not then NO! Left my computer settings so that the monitor would shut off after an hour or 2 and I guess that wasn't quick enough because I now I have 'burn in of the start menu taskbar. If you have either a screen saver or a way for it to turn off (off is best) then you should be a ok.
