Ya I meant "response time" not "refresh rate." Oops. Thanks for correcting me.
Check out my post
#20 on Plasma vs. LCD response time.
A Plasma panel display has near instantaneous response times on the order of 2 milliseconds. The sub pixels of a plasma TV stay alight only for around 2ms when excited. Thus, for example, a 60Hz plasma panel can have 10 pulses per frame, to display the image. Effectively, the screen is being refreshed 60Hz times 10 pulses/frame which gives us a value of 600Hz of some modern plasmas. Now when the displayed frame has to be changed to the next frame, the ultra-fast response times of the Plasma TV sub pixels enables an almost instantaneous transition to the next frame.
Source.
This is why you won't have ghosting on a Plasma.
LED backlit is still an LCD, which means it still has all the limitations of LCDs such as inferior viewing angles, inferior black levels, inferior response times.
Proof that Plasmas don't last long? Most plasmas have a 100,000 hour lifespan. This means a life expectancy of
45 years at 6 hours per day. This is far more than anyone would need; and more than LCDs.
As an "overall" PC monitor (i.e., text), Plasma is not the best solution. However, for
entertainment purposes (i.e., movies, games), plasma is far superior to LCD in almost every respect besides contrast ratio and power consumption. But even if you start comparing power consumption, you'll come out to about $20 per year for an LCD vs. $60 for a Plasma - hardly a material cost when comparing $1000-2000 TVs. BTW, a 50 inch plasma consumes about 275W at full-wattage, which is less than a GTX480. :biggrin:
The 5 best 2010 HDTVs for picture quality?
Plasmas. That's 0/5 for LCDs.
Plasma has been at the top of image quality for as long as I can remember. While Plasma may not be the best option for PC office work, this "old tech" provides the
very best overall picture quality. Modern plasmas have protection against burn-in (and white wash filter option). Even my 2006 Panasonic plasma has no burn-in after all these years of use. Usually people who have never used a Plasma discuss burn-in issues.
