Hi,
I recently purchased this monitor 2nd hand, the seller said it was all right, i got to his home and he hooked it up at his pc, I saw the BIOS screen, bright enoug and so, so said him it was ok, then he unmounted the screen and gave it to me.
Now, when I got home, I placed it next to my IIyama e431S, which uses dvi. (asus x800pro, 1dvi and 1 vga output) I turned it 90° and put it at 768*1024, so it extended my 1280*1024 desktop
. All very nice. Then I tried to adjust the screen to view proper colors...
I couldn't. It seems to show only like a couple of thousands of colors.
image of color panel
that image should be nice and smooth, wich it aint.
and here are 2 images of a picture on my IIyama and the ctx, so you can really see the difference, and the cam makes the iiyama look bad, but it's really good quality on him.
is thi smonitor broke? and if so, could I repair it? or an electronics shop? and would it cost much? or is there something else going on...
I already tried to use an other vga-cable, and connected it with my linux laptop, none solved the problem...
anyone?
anyone?
