Originally posted by: j3ffry
this is the last one please support me(i'll be buying it this week)... I've trimmed it down to Benq FP71G+S and Viewsonic VX724... I'm leaning towards the Viewsonic, but ofcourse I'd be happy to here it from you which one do you prefer..
thanks a lot and more power!!!
Originally posted by: kgraeme
I'd like to see some 4:3 panels in the recommendations in the OP. I'm particularly interested in 20.1" and for gaming. I've seen a few mentioned but don't know what's actually recommended. I've seen the following mentioned:
- Dell 2001fp
- Samsung 204B
- Samsung 204T
- NEC LCD2070NX
- LG L2000C
I use the Dell 2001fp at work and love it for 2D and thought it was okay at games but haven't compared that to more modern panels. I tried a 740B and returned it, so I'm reticent on the 20" Samsung panels. The LG sounds interesting but I don't know if it's significantly better than the Dell that I've used. And the LG doesn't have the USB ports which I would miss.
Originally posted by: xtknight
Looks like the LG L2000C uses the new panel and the Dell 2001FP/2070NX don't, at least for the time being. So by process of elimination, the LG L2000C is your best bet.
That's assuming that newer is better.
Originally posted by: darXoul
kgraeme, avoid the 204t for gaming. Many reports about input lag, just like in case of 214t and 244t...
204b is pretty good for a TN panel but image quality and viewing angles are inferior to modern VA or IPS displays.
If you don't want a widescreen monitor (I'm pretty much in the same boat, IMO: if wide, then 23-24" with 1920*1200 res), the best 20 inchers for you are surely the LG L2000C (new S-IPS panel, fast response time, great viewing angles, pretty good blacks but, strangely enough, some color banding reported) and the upcoming NEC LCD2090UXi (new A-TW-IPS panel, specs pretty much similar to LG but many new technologies, mainly for image uniformity purposes). The NEC should be a good monitor, since already its predecessor, the 2080UXi was a very popular, gaming-capable allrounder, especially in Europe. Its clear drawback is the price.
Originally posted by: SlackerXL
LOL kostyah...
? have a similar question too...
my 19'' crt has to go
and my budget is limited to 700?
I'm thinking of going 20,1'' wide...
Nec 20WGX2 seems to be my best choice around that price
(i'm also thinking of belinea TFT 20,1" 102035W (8 ms)@ 480?
and PHILIPS 20'' 200W6CS (16 ms) @ 450?
could you please post any othr alternative that i might have overlooked
any other input on the subject will be highly appreciated
as i would like to make the purchase within the week
thanx in advance
Originally posted by: kostyah
Hi everyone.
I have about 350-400$ to spend on a new monitor, would 19" be an option or should I buy a good 17"? What are the models that are worth buying in this price range?
Main use will be gaming with some reading \ general use in between.
sorry for my horrible english 🙂
Hi everyone.
Welcome to the forums (and your English is good).
The Samsung 740B and 940B (B, not BF) are decent options for that price range and usage.
Thanks for the reply.
Unfortunately, there is a problem with the models you proposed 🙁 I currently reside in Israel and they don't sell those here. My friends say I should look at-
730B \ 913B \ 930B , are those any good?
http://www.webbuyersguide.com/sub/desktops/reviews/3423-wbgDesktops_reviews.html
First brief review of the NEC LCD2090UXi I found.
Originally posted by: spectra9
Just an update with my bad case of VP930B and maybe a tip for those considering it, make sure you try to display a complete color gradient (like those in MS Paint), and see if there are weird flickering on some color hues, particularly the red ones. I've tried 3 of them and all of them showed the same defect!!
The reason I say this is you may not notice it the first time if your wallpaper and windows color is mostly gray or blue
I don't know if this is my extreme bad luck or just a bad batch of product 🙁
Anyway, I'm trying to work something out with the store I bought it from, maybe replace it with one having similar spec and price range. I tried asking for the VP191 but they say it's out of stock. Any recommendation?
