The Westinghouse does not have a tuner and it's a tad big to be a monitor, but I guess it technically is. I'll probably make it its own little section...
Originally posted by: Keeir
But here's another juncture to point out. TVs display a complete frame with a lag of 32ms, and a half frame ever 16ms.
Yes, it's also interesting to point out due to the bigger crystals on the LCD TVs they can achieve a lower response time than a monitor with the same type of panel.
Xknight could you clarify what your criteria is?
In my eyes a monitor is something 24" (pretty much biggest consumer CRT monitor) or less and has at least a VGA, DVI input, or both. Components inputs or built-in tuners wouldn't change my opinion of a monitor if it's less than 24" and still has VGA or DVI ports. I'd draw the line right after the Dell 2405FPW which is quite a giant in and of itself.
Originally posted by: fierydemise
xtknight, from personal experience I disagree with you on the issue of "ghosting." I have seen ghosting on a fast panel (Dell 2005) and it bothers me, I know many have no problem on 12 or 16ms monitors, but I do. Your paragraph is mostly correct but I would add that the most important thing is to test a monitor and see what you can tolerate, some people are more sensitive to the issue. Either great guide
It's hard to describe this issue, because if you say you can see it a little, people will think you're understating it and make a big deal of it. Then if you say there's none, people won't believe you either. It's like when your girlfriend comes over to your house and you cook a meal, and she says it's "OK". Obviously it tasted like crap, lol.
But I did add people may be especially sensitive to it. I have obsessive-compulsive and it doesn't bother me, so it's probably a visual thing. Kind of like CRTs and refresh rates. 60 Hz looks like a strobe light to some people and to others like me, while it is slowish and flickery, I wouldn't call it a strobe light. Though I do have to set CRTs to upwards of 100Hz until they stop giving me eye strain so it's odd. Out of curiousity what do you see on a CRT at which refresh rate and what about eye strain? I'm nearsighted (can see 12pt text perfect for about a foot from my 17"@1280x1024).
Also, about the screen door issue...it seems to only be noticeable to me when I'm scanning my eyes across on a reasonably uniform gray picture. When I'm playing Battlefield 2 I'd never see it to save my life.
