-Input lag: I couldn't notice any difference between the two monitors in this aspect (yes, I'm relieved 🙂). Several things to keep in mind here:
1. The only FPS I'm playing at the moment is BF2; other games may behave differently in terms of lag.
2. I'm only playing online, with a ping between, say, 35 and 80 ms. The experience when playing on a LAN (3 - 5 ms ping) may be different.
3. I've only played on 1280x960. There's a possibility that the input lag is greater at the native screen size.
4. I'm not saying the input lag is not there, just that it's not noticeable to me under the above conditions. I haven't noticed any change in my level of play when going from a CRT to the 90GX2 and then to the 20WGX2.
5. Enough disclaimers 🙂. The thing is, I can tell the difference between playing with 35 and 70-80 ms lag. The way it goes is that I'd join a server, play for a couple of minutes, notice something is 'different', look at the status screen and there it is - 70-80 ms ping. So, if the monitor would introduce some significant lag, I think I'd notice it.
-Back to the overall gaming experience, all of the aspects above combined make this monitor very easy on the eyes when playing, at least for me. This is the first display on which I could play for 4 hours and not feel any eyestrain (see?!... the kind of sacrifices I had to make to bring you this valuable information!... and no, I don't get to do this every day... I wish 😀).
The OptiClear coating: yes, I had to bring this up again, although it's been debated to death so far. The reason is I have some thoughts on it and I'm curious what you guys think. Basically, it's a tradeoff: you get more reflections, but also better colors and clearer pixels - implicitly, clearer text. I find the latter to be more apparent on 20'' screens because of the smaller dot pitch. I remember looking at an HP LP2065 (20'', 1600x1200) some time ago and thinking 'somehow these pixels are not as sharply defined as I would expect from an LCD on DVI'. In retrospect, I think it was the coating. From what I read on the subject, the matte coatings basically try to disperse reflected light as much as possible to reduce glare; a side effect is that they also scatter some of the transmitted light, thus introducing some blurriness. The glossy coatings rely on different techniques to reduce glare; while they obviously aren't very good at that, they don't disperse transmitted light either, yielding sharper pixels. While I didn't find this obvious on displays with larger pixels, like 19'' 1280x1024, things are different on 20'' ones. I also think I know now why pretty much every laptop you can buy these days has a glossy screen: the dot pitch on laptop displays is getting smaller and smaller, and the effect of matte coatings worse and worse, so the manufacturers had to choose glossy ones, despite the disadvantage of more reflections (I personally find that to be even worse on a laptop screen, because of the position). Do these ramblings make any sense? Anyway, given that I can control ambient light to some extent in the room where I work, I'm now pretty happy this screen has a glossy coating - I really like the sharper text.
And finally, why I exchanged the first monitor: pixel defects. First, I quickly noticed one dead subpixel in the lower left area. On a black screen, I found two stuck ones, one on red, one on blue. As subpixel defects go, the stuck ones weren't that visible during normal use, but the dead one was. At that point, I was already a bit disappointed, as I expected more from a NEC at this price tag. But anyway, now comes the strange part: I started a really thorough inspection on a black screen, and I found... many more stuck subpixels. The thing is, they weren't completely stuck; that is, of the vertical stripe that forms a subpixel, only a part, say, between half and one third, was stuck, and the rest was working properly. These defects were visible mostly on a black screen, at 100% brightness and 100% contrast, and when looking really carefully; otherwise, during normal use, the part of the subpixel that was OK was enough to cause it to appear to be working properly. In total, I found at least a dozen such defects. Thankfully, the guys at the store were nice enough and exchanged the monitor the next day. Now, the new one still has a few such 'partially stuck' subpixels, but no other defects - no dead or 'fully stuck' ones - and the parts that are stuck are very small, appearing like a dot inside the stripe that forms the subpixel. None of them are visible in practice, so I was happy enough to keep this one. But now I'm left wondering: is this a common defect, but something most people aren't concerned about, or not noticing at all? Or was this a particularly bad batch of panels in this respect? Before seeing them with my own eyes, I used to be certain that defect subpixels could be either completely dead, or completely stuck; I had never heard about 'partially stuck subpixels'; have you? I can only hope such defects don't develop into full-blown stuck subpixels over time...
