noname4498
I can notice the blocks on my 997df CRT, they are just really hard to see (blured together), and it has a .20 dot pitch, I am done with CRT's, they give me bad headaches, even at 120hz I can still see it flickering.
Originally posted by: Scorpion
Now I had heard and seen all of the tragedy with the VP930s backlight bleeding. Some of the pictures I had seen I could visible see an X through the whole screen. My VP2030b does suffer from some corner bleeding that is only noticeable on a black screen. The bleeding is not nearly as terrible as what I've seen with the VP930. The bleeding is light and difuses very quickly from the corners and does not propagate to the center of the screen. There is no visible X, just some faint "smudges" in the corners.
Originally posted by: marshallb
Man, I can't decide between the Samsung 17" 740B or the Rosewill 19" R912E for only about $30 more(newegg). They are both 8ms and max at 1280x1024 which fits my needs for gaming. I'm kind of leaning towards the Rosewill because of the extra size, but I want to make sure that I'm getting a great quality LCD. Can someone tell me if the difference between a 19" and a 17" is noticeable?
Originally posted by: prayforMOJO
I'm trying to find a 17" 8bpp monitor that's usable for gaming. I play a variety of games but mostly FPS, RTS, and RPG. I've browsed through the thread but it seems that all the 17" recommendations are 6bpp, so maybe such a monitor doesn't exist, but I'd like it if one did.
The reason I want a 17" is that it runs the same resolution as a 19" but has a smaller dot pitch, so it'll actually look better. I'm a bit spoiled in that regard because I've recently been using a laptop that runs 1680x1050 on a 15.4" diagonal, so it's very fine dot pitch. Being slightly physically larger doesn't really entice me. And if I'm not getting a higher resolution, why pay more for the bigger monitor?
Then there's the question of whether it's worth going from a 17" 1280x1024 for ~$300 to a 20" 1600x1200 for ~$500. I was considering the Dell 2001FP and the Samsung 204T as 20" options, and both can be had for ~$500 (not sure where to look for the supposed coupons for the dell monitor though).
And finally is the question of whether faster response times are worth the reduction in quality. It seems from what I've read that advertised and actual response times can be vastly different, and that the difference between a "slower" 8bpp panel and a "fast" 6bpp can be a lot less than the marketing specs make you think. It seems like a complicated balance between cost, response time, and color gamut. Help is appreciated.
Originally posted by: dman918
Do you recommend using the default color profile from within the nvidia panel, or would you use another one (such as the one found on the viewsonic cd)? BTW, VX924 here.
Thanks!
any others besides the 770P that would be acceptable?
