LCD Buyer's Guide
Page 148 - Seeking answers? Join the AnandTech community: where nearly half-a-million members share solutions and discuss the latest tech.
imported_hyper
13
Sorry for asking so many question and being annoying, but I really need help on this...
So I tried connecting my PS3 to my super-awesome new NEC 20WMGX2 and... uh, I'm not sure how to explain this. There's a problem that's mainly visible on a grey background... I'll try to describe it:
- flickering/flashes of different brightness levels... on and off..
- horizontal streaks of darker grays... also flickering and juddering..
I put up different levels of gray backgrounds on paint and none of those showed up, so it has to be the component input on the monitor.
And another thing, in the manual it describes a 3DY/C option to adjust the brightness and color levels.. this is under Image Controls. I don't see it. =\ I know other options disappear and appear depending ont he input, like the interlaced/progressive ON/OFF feature only shows up when your giving the monitor an interlaced sources (like 480i or 1080i) but I can't find under what condition this particular setting option shows up.
mikuto
40
Originally posted by: 0x0BADF00D
I noticed the same problem some time ago on my 20WGX2 (noise and burn in). I don't notice it day to day, but now that you pointed it out I did some tests and it's the most noticable with uniform rgb (20, 20, 20) to rgb (40, 40, 40) more less.
Could you provide a bit more detail on how you tested for the burn-in problem, please? Is the gray level range you mentioned related to the noise problem, or the burn-in, or both? Thanks.
The reason I'm asking is that I'll have 10 days to return my new 20WGX2 once it arrives (no, it's not here yet, darn :|), and I want to put it through all the tests I can think of in that time frame. It's unlikely I'll be able to get it exchanged afterwards under warranty for such 'subtle' issues as burn-in... most likely they'll point to the user manual that states something like 'some burn-in is to be expected', and they'll pretend it's not a problem, but a feature.
QueBert
23,052
1,222
Originally posted by: Matt2
Well I went to CC last night and bought the Gateway FPD2485W on impulse. CC was selling it for $649.99 so I hit my $700 limit right on the nose after taxes. I decided to go with this Gateway instead of the Dell 2407wfp from I^2 because I felt a lot safer buying from a B&M store.
After reading the reviews about this monitor I expected to return it first thing this morning.
I must say that I am impressed by this monitor. It might have helped that my expectations were lowered by reading the user reviews here on the forums, but I am impressed none the less. The panel I received had almost perfect backlight uniformity, maybe a little bit brighter on the bottom, but the difference is negligible. No dead pixels at all. Response time is fast, but there is a bit of problem with "smearing" on dark colors. If I run the mouse pointer over a black or dark webpage you can see a black smear trailing the pointer. This sounds really bad, but it's very subtle. I literally had to put my face up to the monitor and run the pointer back and forth to see it. If I hadnt read about the issue on {H}OCP forums, I might not have ever noticed.
Then there is the issue of banding. I heard that this monitor had horrible banding problems. I ran xtknight's gradient linearity tests and there is indeed banding, but it's about 100 times better than people make it out to be. It's a little worse than my Dell 2007wfp (S-IPS), but I cant see it being any better on the 2407wfp. I played a couple hours of XBOX 360via vga cable on this bad boy and I didnt notice the banding at all while gaming except for the main menu in splinter cell: DA where I could notice it a little bit. All in all, the banding issue was definitely not a deal breaker for me.
The colors out of the box were a little too saturated and a little too bright for my tastes. I used an ICC profile provided by Jarred that was supposedly professionally calibrated and now everything is right where it should be.
All in all, I really like this monitor. Last night I wasnt so impressed, but now that I have everything set to how I like it, I think its a great monitor for a great price.
Now what to do with my S-IPS 2007wfp?
Saw the sreeen on demo at Best Buy, I had nowhere near the $679 it costs, and I don't know how to wait, so I ended up getting the Westy 22" ($320) I too have read some not so great reviews of the GW, but daam it looked incredible in the store :)
0x0BADF00D
22
The burn-in seems unrelated to the other issues, and is easy enough to test. In my case, a white window on a black background does the trick. Say, open a PDF file, leave it for 30 minutes (I haven't really timed it, or really bothered with the whole issue all that much). After you close it, you should be able to see faint outlines of the windows text still present. That's burn-in. Mine goes away after a coupla minutes. It doesn't bother me too much, I just don't want it to get worse. Also, I suspect it's worse at higher brightness levels, though don't quote me on that.
The noise issue appears to be VGA only, and was identical on the other unit that NEC showed me. Try full-screen solid faint grey colors. It's more visible at high brightness, and movie modes. If you do have any noise, you will definitely see the difference between VGA and DVI. DVI is rock steady. VGA has very rapid fine shimmer. BTW, my LCD20WGX2 has revision # 1B. I didn't note down the revision # of the other unit I had a look at yesterday. Hope you get a good one. Mine is not perfect, but still miles better than the 2 Dell 2007WFP's I returned before.
xtknight
12,974
Originally posted by: Zebo
XTKNIGHT you really think a PVA like Samsung 215TW is going to be better than LaCies 321 or NEC's 2190UXi? I assume so since you say #1 constitutes best in category regardless of price. However the later is geared toward high end desktop publishers and those makers would have switched to PVA if it were at all superior. I havnt seen either but knowing what I know about IPS and PVA I don't see how one can recommend like you did. The later also have 12 bit lookup tables and even come with hoods and calibration devices. The later costs 2.5x more so why would it be worse? usually things that cost more are better... In fact on the desktop publishing and photo editing catagories you don't even have *any* 90i series NEC's or Lacie which is their primary specialty..go to the digital photo forums you'll see thats all they like to use. Any thoughts?
My thread is mainly geared toward LCDs that are under $2000 (i.e. consumer LCDs). I do make some assumptions that people already know about the super high-end LCDs. When you think about it, when's the last time you've seen a review of a really high-end LCD? X-Bit does two maybe every six months, and BeHardware occasionally gets a sample but I just don't have enough data to rank the high-end LCDs amongst each other. Adding them up there would just clog up the list since the market for them is extremely small. Most of the time, people with special needs would just make a reply to the thread rather than just go off an item on a list, as well. They are spending a lot of money, so they are going to do more research. If they made a reply and stated a high budget, there's no doubt I'd let them know about the higher end ones.
Although there may be some better LCDs in the >$1500, <$2000 range I will have to say that these are the least reviewed of any, therefore I cannot recommend them.
Anyway I just ordered a 1990FX for my dad for bday who is going close up blind at 70 so needs huge pixels:p and it was not on your list. Just based on high price and with knowledge IPS is superior. Did I make wrong choice?
I doubt it. NEC just doesn't make bad expensive monitors. An IPS is an IPS.
xtknight
12,974
Originally posted by: Sokratz
Thanks xtknight, I really appreciate your suggestions. One question on the Dell, you had mentioned some banding issues under general issues? Is that still a problem with the latest revisions?
Nope, it has been solved since A03. AFAIK they added a smoothing algorithm, which is actually quite surprising but it does the trick.
Originally posted by: moogen
tried finding my answer on here, but this thread is a big MONSTER!! :p i'm looking to buy a gaming monitor, and was pretty much settled on a 22" widescreen LCD (the acer, as a matter of fact). i figured 22" was the sweet spot as the price jump from 20" to 22" is relatively small, and the jump from 22" to 24" relatively big. HOWEVER, recently i've been reading about how you need to make sure you have a strong enough vid card to run the lcd at it's native resolution, etc. i'm planning on getting a 7600GT, or something about the same power. i've also been reading if about how if gaming is your primary focus (and oh, it is:) ) how a regular 3:4 ratio might work better than 16:9 (or 16:10). what's your thoughts on this? am i better off getting a regular ol' 20" monitor than some 22" widescreen jaziness? i'm in the market for a sub-$300 monitor, what models might be good for me? thanks!
All the posts I read seem to indicate that widescreen is better for gaming. A relatively recent poll here agrees, so I'll have to say that "4:3>16:10" is not a common stance. I'll recommend the Acer AL2051W (glossy) 20" wide to you.
Could be the "I/P" mode, other than that I have no idea. Never hooked up a PS3 to the NEC. It is probably just the VGA/component input processor doing the best job it can at using the available signal.
imported_hyper
13
Oh man, the same thing just happened while I was just browsing the net. It's like the backlight is faulty or something, I don't now. Brightness level changes for a split seconds, like a flicker.... it's really obvious when you go to a site like 1up.com and stare at the gray sides for a few seconds...
I'm thinking about getting another monitor, like maybe the 206BW, but I have no idea what to do with this one. :(
Zebo
39,398
19
Thats normal. Turn off Advanced DV Mode to make go away.
imported_hyper
13
Thanks! The problem also improved noticeably after I took out the stock single-link DVI cable and switched it with a dual link one.
imported_hyper
13
:confused: What's the difference? Got pics?
Sorry I don't have a camera. I just read that dual link transmits more information and thought this could be a reason for the problem I'm having, I don't know... I switched the cable and saw an improvement in that brightness flicker... of course it could all be a placebo. effect or something. :p
:eek:
And dude, that signature is... tacky... sorry, don't mean to derail the thread or anything, but wanted to mention it. I'm an atheist so I suppose I shouldn't care, but I was raised as a muslim so maybe that hit a nerve or something. [/OT]
mikuto
40
I would recommend going for a more powerful graphics card if you want to run games at the native screen size of 1680x1050; anyway, that would apply to the 4:3 form factor as well, since at 20'' it generally means 1600x1200 as far as I know. I doubt the 7600GT will be able to handle such screen sizes at any reasonable quality level in most modern games; I'd say a 7900GS would be the bare minimum if, as you say, gaming is your primary focus ;).
Torque79
16
well, I picked up the 22" LG yesterday. Only got to play with it a bit, but so far so good. I forgot the driver cd at work so I'll install it tonight. I am very impressed with the picture quality and brightness so far, though I think the brigtness might even be a bit too much! It's frustrating now looking at some of my videos etc which are avi's/xvid etc, much easier to see the pixelation from the low res picture. :( I love how WoW looks on it though, stunning.
I was surprised to find LG does not have drivers for this monitor on their website at all yet, and also that ALL LCD drivers are contained in a single zip file rather than allowing you to download the driver just for your monitor. seems dumb to grab EVERY LG lcd driver when you only need one.
a friend of mine is going to lend me a software/hardware solution that helps calibrate your monitor for true colour output, white level, etc. He's big into photography, so I'm guessing this thing will help calibrate it really nice.
edit: he now told me it's a spyder2 unit, looked it up on the internet and sounds great. gonna calibrate my projector too!
thanks for the recommendation, I love this LCD.
xtknight
12,974
Originally posted by: chefazn
i have the a01 dell 2405 and i'm seeing dark spots, should i get it replaced?
I don't see why not. Sounds like a panel pressure problem to me, or perhaps some burned out backlights.
Zebo
39,398
19
None of the monitors I mentioned are close to $2000. For example the Lacie 320
which comes with a $250 colorimeter and $200 hood is $1250. When you consider the "freebies" the monitor is more like $800, not too far away from mainstream 20's. Granted it's not a $400 LP2065 but it's a lot better too. No lotto, grade A panel better electronics and such. Toms in every review still uses the 320 as their top reference point for color quality. I just don't understand how you can say best regardless of price and not include professional monitors like these. It would be more accurate to say best price/performance that way you could include TN's too which should not be on any recommend list with a caveat about price/performance.
mikuto - Geez it's taking a long time to get your NEC who did you order from?
xtknight
12,974
Well you're right, it is pretty 'cheap' without the other stuff. I haven't seen a single review of the LaCie 320, though. I don't recall seeing it in THG's reviews ever, but if you could provide a link that would be great.
I just don't understand how you can say best regardless of price and not include professional monitors like these. It would be more accurate to say best price/performance that way you could include TN's too which should be on any recommend list with a caveat about price/performance.
By and large, I really dislike TNs and make an effort to avoid them whenever possible. That doesn't mean some won't be on the list, but not too many will be (except in Gaming where they practically dominate). For somebody who is not willing to spend $250 on their monitor, the LCDs under that price point don't vary much in quality: that is, they are all of fairly poor color quality.
You could say my list is rather utilitarianistic, but that's all I really intended it to be. Simply put, the market for those LCDs is so small that I just haven't gathered the time to bother maintaining a pro photo editing section. In addition to that, like I already said, the reviews are pretty sparse on the high-quality CCFL pro LCDs. The LED ones are actually reviewed quite often, but these are way expensive for most people.
For now a simple note will just have to suffice. That is, when buying a photo editing LCD, please:
a) Reply to the forum so that you can get a good, accurate recommendation, that is if I can even provide one for your needs.
b) Reply to the forum so I know there's still a market for such LCD recommendations.
That I recall, I have not had a single person inquire about 'pro' photo editing LCDs. It would take a while to search the whole thread for such questions, but if there was such a question it was quite a while ago. I can tell you with certainty that if my memory serves me right, I have never had anyone with a budget of over $1500 for any LCD except an HTPC LCD. That is, never $1500 for anything under 32" or so.
When people want to spend this much on an LCD, it simply needs to be dealt with on a case-by-case basis. Very rarely does someone at home only do photo editing (and to tell you the truth the LaCie could be horrible with regards to ghosting). Most photo editing/business users have contracts with NEC/Eizo/LaCie already thus bypassing any need (or even want) of research automatically. Being tied to a company like that, they might not even have a choice.
The LaCie 320 is actually an odd duck in that it is not a whole lot more expensive than some consumer LCDs. So yes I would consider placing that in the prosumer section, but again I have yet to come across a review for it. Lately I have not had the time to dig deep like I used to, so if you ever come across deltaE, contrast, and gamma measurements for it I'd be grateful. I can say that I have not seen it at the usual sources. A full review is much more preferable than a brief mention of the dE94 measurement.
So, in a nutshell, I do not have a pro photo editing section because:
a) I do not feel comfortable recommending LCDs that are not often discussed and critiqued.
b) The pro photo editing market is very small with most needs already satisfied via a contract or otherwise.
c) People with such needs should definitely be replying to the thread and making a special inquiry. Even people with needs already covered by the general recommendation list in here ask.
d) The monitors in this sector are way out of most peoples' budgets.
e) These LCDs, after calibration, are rarely much better than the IPS LCDs recommended in the prosumer photo editing section.
f) The demand is low, and digging up reliable or full info on them is often impossible. Finding brief mentions of calibration results for these monitors on Danish, Polish, Czech, or Chinese sites is time consuming since I don't speak anything close to any of those languages.
g) They are in a completely different sector, one I don't specialize in. I can't go off "previous experiences", "precedents", "trends", or "patterns" of any kind when I recommend these LCDs.
You may think I tend to only spend time on what the majority wants, here. I will have to say that's mostly true as a matter of fact, but if once in a while I need to assist someone with their research of pro photo editing LCDs I would certainly not mind that. At the moment I just do not see the demand nor the data I need to maintain a section geared toward the general public for it. What I will do is make a stub section with a couple notes, including a request for them to reply specifically with their exact needs and an offer to assist them in any research they need, to the best of my ability.
If there are LCDs that fit the prosumer section under the $1200 or so threshold, then by all means I would love to add them. But with such expensive LCDs I can only do that if there is a good full review of it. I have not seen such a review of the LaCie 320. My aim is to keep the recommendations highly accurate, and the rate of error low. In order to do that, I will have to shun the "true pro" section for now.
FWIW, Tom's actually has a new review out just today: http://www.tomshardware.com/2007/03/08/four-wide-screen-19-monitors-compared/
I do plan to add the NEC 26" as soon as I get a chance to look up some more info about it. I hope I answered your question. I intend to keep the prosumer section as accurate as possible. I also intend to somehow satisfy the increasingly small population who wants photo editing LCDs. I'm all about trying to make everyone happy and unfortunately that is unfeasible at the moment. Right now I can not think of exactly how I will satisfy this particular sector, but it probably won't be by recommending specific models. We'll see there, you've certainly got me thinking.
Zebo
39,398
19
Hey I'm not coming down on your excellent work and research I just wanted to understand better about the "best regardless of price" thing.. Makes perfect sense to include some idea of a reasonable price point and needing thorough reviews. Thinking about that way even after a very expensive monitor does well in a review it maybe shouldn't make the list just because it's too damn expensive for 99% of people reading the list. I'll try and find you all the reviews I've seen of the pro monitors, they are out there, and we'll chat via pm further to avoid clogging this thread with discussions about methodology.. Toms regularly goes on about the 321 (not 320 sorry:p) for example:
http://www.tomshardware.com/search/sear...tle%3ADisplays&ip=209.68.60.14&start=0
Wide Format LCD Monitors: Part 2
Location: Tom's Hardware / Graphics & Displays / Displays
... That also explains the results of the previous LaCie Blue Eye test. Spatial Uniformity. ... Still, pros will prefer a LaCie 321
Do You Want a 16:9 LCD Monitor Now?
... do very well for photo and graphics work. Still, pros will prefer a LaCie 321, for example. With its 1920 x 1200 resolution, the ... 2006-1-31
As far as dE. It matters little XT and it's certainly a highly overrated stat. Theoretically even all TNs can be < 1 but why we love IPS so much is they do at angle while other tech don't/can't:) So how much does dE really matter in the first place? None to me.. Only one qualification is needed for accurate color: is the monitor an IPS or not. IPS?, good, now we can talk about DeltaE.
Excellent explanation from xbit of this idea.
Many people associate different quality of color reproduction with different matrix types: the best quality with S-IPS, the worst with TN, and MVA and PVA are somewhere in between. This is not quite correct. The quality of color reproduction is formally described with the dE parameter which shows how much the displayed color differs from the etalon one. Not an integral parameter, dE must be calculated separately for each of those 16.7 million colors the modern monitor can show. The smaller dE is, the more accurately the color is reproduced.
It is accepted that the average person can easily see the difference between two colors at dE>3. For working with color seriously, the monitor must provide dE<1 after calibration. But theoretically, monitors on each matrix type can be calibrated to this accuracy. Moreover, the actual result of calibration depends on the monitor?s electronics and the calibrator you use, so if you take two specific monitors on TN and S-IPS matrixes and calibrate them, the dE parameter of the former may prove to be smaller than of the latter, and there would be nothing wrong about that.
However, no one tries to use TN matrixes for processing color. Why? It?s because the dE parameter describes the color reproduction accuracy as it is perceived with the line of sight being strictly perpendicular to the screen. Colors on modern S-IPS matrixes with viewing angles of 178 degrees suffer almost no distortion when the user moves his head to a side. On TN matrixes with their narrow viewing angles you don?t even have to move your head: colors look different just because you see different areas of the screen at different angles. Try to display a solid-gray background on a TN matrix and you?ll find it next to impossible to find a position for your head at which the background would really look the same on the entire screen. You move your head up ? and the bottom gets brighter, you move your head down ? and the top becomes darke
So, the different matrix types suit differently for working with color not because of the numerically expressed color reproduction accuracy, but because of the matrix manufacturing technology, namely because of the viewing angles. A monitor whose output picture is noticeably distorted as soon as the user moves his head just a little does not suit for work with color however carefully you may calibrate it.
Comparing the viewing angles provided by different matrixes, we can easily see that S-IPS yields the broadest ones. S-IPS matrixes don?t distort colors even if your line of sight is deflected far from perpendicular, only the contrast suffers a little. A drawback of S-IPS is that black appears to have a violet hue when viewed from a side, but this effect isn?t very conspicuous on modern S-IPS matrixes.
MVA and PVA matrixes are second best, distorting colors somewhat more than S-IPS does. Moreover, these technologies both have one defect: they lose details in shadows when viewed at an exact perpendicular to the screen. But this defect is almost totally corrected in the last generation of such matrixes, called S-PVA.
Finally, there are TN matrixes with very poor vertical viewing angles. It?s hard to find a position for your head at which the same colors at the top and bottom of the screen looked identically. And if you try to move your head about, the colors are distorted wildly.
From a "pro" review
http://www.xbitlabs.com/articles/other/display/professional-monitors_3.html
A couple more professional grade monitor reviews
http://www.macworld.com/2006/06/reviews/2190uxi/index.php
http://www.shutterbug.net/equipmentrevi...oftware_computers/0307lacie/index.html
http://www.lesnumeriques.com/article-203-1026-52.html
http://www.pcmag.com/article2/0,1895,1934595,00.asp
Oh and I think you'll find this link interesting allowing users to find reviews of any monitor (maybe even any piece of computer hardware) By no means inclusive of all reviews but should give a user a good start on looking for a review you have not discussed.
http://www.findproductreview.com/Computers/Displays/Monitors/LCD-c-138.html
mikuto
40
Please, don't get me started :). Unfortunately, Eastern Europe is still far behind the western world in terms of sales volume (and implicitly retailer stocks) for more expensive monitors. There's hope for next week.
imported_hyper
13
Anybody knows what's the deal with the DVI-HD mode in the NEC 20WMGX2?
I heard it makes the image look horrible, but I can't see it. What am I missing here? Maybe there was a revision and they fixed this perhaps...? o_O
xtknight
12,974
I don't even know what the DVI-HD mode is supposed to do. I see no difference, personally.
stimpy1
205
Hello. I'm an LCD noob. I do some gaming (WOW, BF2), a lot of office documents (particularly word documents), some web design, photo editing, surf the net, and use my computer to watch movies. Per those requirements, what is the best LCD for my needs that fall within a $450 max. price range? I'm not particularly sure if i want a wide-screen LCD or not, although I have heard that they can be useful for pulling up word documents side-by-side. I've noticed that some LCD's have a grainier picture than my ancient Sony CRT, which drives my crazy! I definitely want something that is crisp and clear. If you could make some monitor recommendations, it would be greatly appreciated. Thanks.
xtknight
12,974
If you want something clear, then I'll have to guide you towards the Acer AL2051Ws with a glossy screen. Yes it is widescreen, though you may be disappointed with anything less than a glossy panel. I have used the HP LP2065 (S-IPS that would generally be recommended for your purposes) and it seems particularly grainy compared to my glossy 20WMGX2, despite having a small dot pitch.
