Originally posted by: Rapishorrid
Thanks for the advice xt. The L204WT sounds great except I am worried a little about the native resolution. IIRC the native res is 1680x1050, so would that mean that I'd have to run all my games at that? (or at least to make them look decent) Sorry I am a bit new to LCD's, that's why I am here!
You have two options and a few sub-options:
a) send the monitor a 1680x1050 native signal
_1) by having your video card process 1680x1050 (perfect quality)
_2) by having your video card process a lower resolution
____options for NVIDIA cards: aspect ratio scaling, centered mode, regular scaling (lowest quality)
____options for ATI cards: centered timings (does not always work properly) and regular scaling
b) send the monitor a lower resolution (you're at the mercy of the monitor's scaler and scaling options on this one)
____options for monitor: varies (some offer aspect ratio, 1:1 [centered mode], and regular scaling)
Got that? Good.
The point is, you will have to sacrifice the image somehow for it to be displayed on a 1680x1050 pixel matrix. Centered mode just places it in the center and surrounds the image with black bars, but the quality is obviously 1:1 because the image itself is the same size. Aspect ratio scaling should be higher quality than regular scaling. It just scales up one dimension and leaves black bars around the other. It maintains the aspect ratio (width/height) of the image to preserve as much quality as possible. But it still doesn't look that great for most things.
The video card should be able to scale any resolution, but the monitor can only scale a select few presets put in place by the manufacturer. Most can scale at least three of these: 640x480, 800x600, 1024x768, 1280x720, 1280x800, 1280x960, 1280x1024, 1440x900, 1440x1050. For LCDs, I would aim to push a 1680x1050 image at lower image quality settings instead of using high settings at a low resolution. I couldn't stand being at non-native for any prolonged period of time for 90% of the things I do (mainly just desktop usage, and the scaling is only OK for a couple primitive games).
But if that's the case, can you recommend any 19" non-widescreen lcd's for my purposes?
The NEC MultiSync 90GX2 (first) and Samsung SyncMaster 940BF.
