GoodRevrnd
Maybe I should buy all the 2025's in my area just to resell. =p
Originally posted by: Kung Foo
About the Philips 200WP7ES 20.1" again.
Philips customer support confirmed for me that it has an S-IPS panel.
They did not have the information about the panel type itself (and said that it is concidered confidential information anyway, and might change over time).
Seems that my old 17" VieWSonic is really taking its last breath, so I decided to take the risk and order this "sounds good in paper" LCD. Perhaps I'll write a note about it also here when I get it shipped.
Kinda frightening just buying blindly like this, since there seems to be a lot of crappy LCD's on sale nowadays. But I hope its enough that its S-IPS, and at least the specs say that it cant be that old panel either (8ms S-IPS panels are not that common yet).
Originally posted by: xboxist
xtknight --
What monitor would you consider the "best" in the 20" lineup, outside of the NEC that you own? Also please consider the following criteria:
-- I'm not taking a chance in the Dell lottery
-- I can't find the VX2025WM anywhere
-- Usage emphasis would be equally shared on gaming and movie watching
What 8-bit panels exist beyond this?
I'm not sure I understand that test shows it's lag independent of the pixel response though. At least in a rapidly changing scene it seems the delay of a pixel having to change colors alone would leave the scene always a few ms behind.
"Where does this delay come from? It?s hard to tell for now and we will have to investigate a little more."
Do we at least have an idea of whether it is inherent to panels or more to do with some other back-end circuitry?
For instance, I heard "pro gamers" bitch about the lag first hand on that Samsung 931c that's the "offical WCG monitor." And this is the winning team that was complaining.
BTW, do you think it's worth foregoing a boxed Viewsonic VX2025WM for $200 to get the NEC for $650? It's such a massive price difference, but the glossy coat... and the multimedia inputs w/ PIP would be awesome. I also wonder about the response time difference since the Viewsonic can hit twice as high. I've been on a high quality CRT for 5 years now and it's still goin' strong. So I even wonder about waiting for something significantly better. (Pipe dream...)
For those wanting a VX2025, Officemax has them on clearance for an additional 20% off today and tomorrow, coming out to $228.
I decided to grab one of these and will spend the weekend deciding if I like it or not. If I don't, I'll probably pick up an NEC shortly after Christmas, if I find it satisfactory it'll be used as a secondary monitor in a year or two when more sophisticated LCDs come out.
xtknight --
Originally posted by: Pyrii
"Philips 200WP7ES has a inch 8 ms (g2g) S-IPS (LG.Philips LM201W01) eller et 8 ms (g2g) P-MVA panel."
Which, according to philips brochure:
Model: LM201W01
Resolution: 1,680 x 1,050 WSXGA+
Aspect Ratio: 16 : 10
Number of Colours: 16.7 M (8 bit)
Brightness (nit): 300
Colour Saturation: 72
Max Contrast Ratio: 800 : 1
Viewing Angle: 178/178?
Response Time(ms): 8 (GTG*)
Interface: LVDS
Outline Dimension: 459.4 x 296.4
Thickness: 22.8
MP Schedule: MP
And yes I did type that out by hand, from http://www.lgphilips-lcd.com/homeContain/jsp/eng/prd/prd200_j_e.jsp and clicking digital catalogue.
Originally posted by: xtknight
Sadly, the Philips 20" widescreen S-IPS is not available in the US. The model number is: 200WP7ES
Well, it turns out that the AL2032wa isn't available in the US anymore either. Well folks, the NEC 20WMGX2 is the only 20" widescreen, fast panel under $600 that uses a S-IPS (or even S-PVA, P-MVA for that matter). The manufacturers decided that people buy the TNs and that it is not worth it putting in P-MVAs or S-PVAs. I expect that trend to continue. A 27" TN panel is coming soon. Fortunately, the newer TN panels have great dithering/FRC algorithms. Backlight bleeding is still a huge problem, though.
What's the word on the vx2035?
Another question (ugh... I've asked so many, but I super appreciate your time xtknight, and others):
Regarding the 20WMGX2. Sometimes I see pictures of it with the speaker bar. Sometime it's not there. Is that from people taking it off, or is there a speakerless version that one can buy?
So, I don't know if this Viewsonic panel just isn't good for me, I have something configured wrong, or I'm being too picky. It doesn't seem like ghosting, I was under the impression that was a more smooth smearing.
The effect is most noticeable against edges, such as a door frame in the game. Rapid movement shows different parts of the door frame completely misaligned, in PERFECTLY proportioned inch and a half blocks.
You can witness the same effect on the desktop with a black background and dragging the selection box back and forth rapidly.
I have to add the screen door effect on this monitor is really bad. I don't notice it much in most gaming situations, but it drives me nuts in basically all desktop work. They made a really bad choice with their anti-glare coating.
I have discovered that V-sync off was about 90% of the problem. With it on, it is still very noticeable to me (less so in games), but tolerable. Is there a way to enable Vsync on the desktop? I know it's not really important there, but the tearing of moving windows around is still pretty irritating. Also, is it better to run my 2025 in 60hz or 75hz?? I was under the impression that true 75hz panels don't really exist, so...
And now that I have my 2025 hooked up side by side with my old Sony G420 CRT, I look on it more favorably now. My poor poor poor Sony monitor has really taken a dumb in color clarity. Doing it's image readjustment thing clears up the washed out effect it seems to get with time, but I have to do it more often than I used to, so it seems apparent this thing is on it's way out.
If only this SDE wasn't so irritating for desktop work. I still think for $200 this monitor was a disgustingly good deal. I have 2 weeks to decide if I'll keep it.
Originally posted by: Frankie
I received my NEC 20WMGX2-BK Widescreen from Newegg on Wednesday night. My first impression is WOW!!!! This thing makes my 17 Hitachi LCD look like crap, and I payed just as much for that one in 2003 than I did for this Widescreen one now.
No Back Light Bleed to speak of. No dead or stuck pixels. The image persistence that some of the reviewers on Newegg mentioned is non-existent as far as I can tell. I run my screen saver and have my computer shut the monitor off after 15 minutes of non use and I've had no sign whatsoever of Image persistence. A GREAT monitor, and with the $50 rebate if you buy it before December 31 is the icing on the cake for me.
Just one thing I need to ask xtknight. It's only a nuisance to me, however when I switch from TV to PC or if I change the DV mode or if I hit the display key to see what mode I'm in the box that comes up won't cut off by itself. It turned off by itself initially but not I have to hit the menu key to turn it off. Not sure if did something or not when I was messing with the controls while playing with it. In any case, is yours like that and if not how to fix it? Again, not a huge deal and nothing to make me want to RMA the thing back, just a nuisance.
...This monitor situation is really getting frustrating. First of all, I purchased a 21" Gateway (purchased Gateway computer system, but I returned before opening the box when a call to Gateway revealed that the AMD processor did not have the AM2 chip...). So, I decided to get a core2duo laptop (I know, I digress...). Anyway, Circuit City stopped carrying the 21" Gateway; so, I decided to get the 21" HP (I think it has the same panel). It was on sale for ~$369 - you guessed it, none of the stores around me have that one (and it is out of stock online). So, I decided what the heck, order the Dell. Then, I realize the panel issues... Then, I think I discover a "find" at Wolf Camera (of all places), and what do you know, the price has just gone up over $100. I have more should've, would've, could'ves than I care to discuss (or should I say disguest)🙁
Now, I am guessing that I should have gone with a desktop after all - this laptop (and a $500+ monitor) is really getting expensive🙁
