If I get a machine with hand dials. What would be the better to have the dials graduated in?
Say I have a rod I want to cut into some sort of custom bolt.
I want to cut the shaft diameter in SAE, but the head in metric. Would it be easier to do that on a metric graduated mill/lathe, or on an SAE graduated mill/lathe
mm/25.4=in
One can be made into the other. Math FTW.
Get the units you are most comfortable using.
