Jaepheth
Not car related, but this seemed the most appropriate forum...
I like to do occasional hobby work that sometimes involves fabricating my own parts for various widgets or modifying existing things. I probably won't be making anything too complex, mostly just need to cut blocks of aluminum/wood/plastic/mild steel with reasonable precision.
Towards this end I'm thinking of getting a Smithy 3-in-1 Lathe/mill/drill press (Probably Midas line ~$2K) Any thoughts on my choice? Are there better brands at comparable price? Would it be better to get separate machines for each function (perhaps Sherline)? I'd like to keep price below $3K total.
I'm also assuming (As I seem to remember my father doing) that a machine and bits that can turn/cut/mill mild steel will be able to do the other materials without a problem. Or are wood turning tools designed different in some way?
