Laptop Power Supply Question
jacktesterson
5,493
My power supply for my Latitude has a short in it.
Rather than screwing around with it, I have a Spare 150w Official Dell power supply meant for a Alienware M17x Laptop laying around. I purchased it when I had my M17X as a spare, and it's never been used. I forgot I had it till I was digging through my parts closet. My Latitude's PSU is only 65w.
The plug is the same size. Am I safe to use it with my latitude? From my understanding it should be ok but want to be sure!
C1
2,425
133
If it is the same voltage, polarity and number of wires/terminals (some note book supplies employ three wire systems) it probably will be okay. Test the whole thing out carefully with a good meter before you proceed since any mistake could be costly.
DesiPower
15,299
740
I would say that since they are from the same company, all you need to worry about is the voltage rating, if that's same it should work without worries...
