Okay I have a gateway 7405gx Its about a year and a half old. A couple months ago it just started shutting down for no reason. Only thing that happens is the fan starts up and then it just shuts down. This was okay for a while then it started happening after about only having the computer on for 15 minutes. So I decided to do a system restore and I cant even get through it without it just shutting off. Any suggestions on what is causing this nad is it a easy fix or should I just move on. Thanks
