Question Laptop CPU in a Desktop? Ultra Low Power Desktop?
killster1
Banned
Mar 15, 2007
6,205
475
aliexpress sells intel laptop cpu's soldered to a a adapter board i havnt looked into it a lot but you will need to modify your bios to get it to run in your desktop motherboard.
mikeymikec
21,110
16,318
@wacki
When you say 'in your desktop', is this a computer you're thinking about getting/building? The reason I ask is that if you're still in the planning stages then you might want to consider an Intel NUC. I got one for a customer several months ago and they're basically about 8cm square and the height depends on whether you want room for an additional 2.5" SATA drive (alongside the logical choice to use being an M2 SSD).
Intel NUCs are typically powered by laptop-class CPUs and they also have the advantage (at least the one I looked at did) of being VESA mountable so you screw it to the back of your VESA-mounting-capable monitor.
The NUC I went for had an 8-series i5 laptop CPU in, so quad-core. You add the memory, storage and OS yourself.
killster1
Banned
Mar 15, 2007
6,205
475
i tried looking it up, just because it sounds interesting, and cant find one
here is one of the video's ive seen with the idea. i use a similar cpu in one of my nuc's (ive gone to nucs with nas / das for the storage needs)
Reactions: JWade
Pohemi
10,889
16,977
AMD AthlonXP Mobile 1800+ to 2500+ chips were socket A and would run in desktop boards.
That was nearly 20 years ago now though, and I'm not sure there's been too many similar products since then, if any.
As some of the other posters have stated in here, look at an Intel NUC, imho. It's likely all the power/performance you need, in a tiny package that sips juice (wattage).
TheELF
4,027
753
You could get a laptop if it would be at all useful to you, connect a keyboard and mouse and a monitor to it when your at home and you wouldn't be able to tell the difference.
You could also go with a J series CPU, those are soldered to the mobo so no upgrade but they are very low power and you get a case for expansion cards.
bigboxes
42,342
12,425
Yeah, I remember that. I was thinking of this very thing when I read your post.
