Laptop battery
christopherprevails
10
I've heard both sides of the story. Which is the best to do - take the battery out when plugged into the AC adapter or leave it in? (Granted the battery is at 100% charge)
No cross posting of topics. The one you have in GH is the best place for this topic.
esquared
Anandtech senior Moderator
ch33zw1z
39,472
20,154
Shutdown, Remove without A/C power plugged in. Plug in power, power up the laptop
imported_Baloo
1,782
What are you getting at? If you want it out, leaving it in is bad, if you want it in, taking it out is bad. What is it you intend to accomplish?
christopherprevails
10
I thought it was self explanitory that I was referring to which was the better idea for preserving the life and performance of the battery.
