Markfw
- May 16, 2002
- 27,413
- 16,272
- 136
you should unlid the cpu. there are no exceptions
Wrong.... Just wrong
Generally lapping high end heatsinks lowers performance. They are bowed for a reason.
Markfw900 said:Wrong.... Just wrong
huh you know I was just about to lap the stock heat sink on my amd 5600+ since it runs hot,like 52c and 60% load with a room temp of 70f.
after reading this the question is should I?
Since you had to ask, the answer is a definite no. You don't lap solely for improved temperatures. It is for the people that have a love for the hardware and want to maximize its potential in whatever bounds are set.huh you know I was just about to lap the stock heat sink on my amd 5600+ since it runs hot,like 52c and 60% load with a room temp of 70f.
I lapped my 930 and a few c2d.
I only use a HSF to run off a new mb out of case.
Does the extra weight and flex of a large hsf on a vertical mounted mb add to tempeture problems.
Would the use of a oc station were the mb sets flat be better then a case mout when using heavy hsf.
AFAIK, you can get a few extra degrees more by unlidding the CPU. It's not something I'd recommend for your average plug and play tinker-tot, but it's a proven tool in OC'ing
You only lap when you've got a shit ton of money, you're pushing everything to the limit already... (cooling wise and overclocking wise) and you're like, "How can I squeeze 50 mhz more out of this?"
I've lapped the IHS on an Athlon X2 and it did result in some gains...but honestly the few C reduction in temps is not worth the effort. Get a better heatsink if you really want to reduce your temps by any meaningful amount.
but please beware: I am more of the lucky ones I suppose to achieve cooler temperatures at same speeds between stock and lapped IHS & cooler. I have read and seen cases where shit hit the fan after a lapping session.
you think it's worth it, of just like the idea of a mirror finish CPU IHS... well you know the deal. . . .
Why do you need to have a shit ton of money to lap a CPU? If you spend more then ten bucks, then either you have been seriously robbed or you did something seriously wrong.You only lap when you've got a shit ton of money, you're pushing everything to the limit already... (cooling wise and overclocking wise) and you're like, "How can I squeeze 50 mhz more out of this?"
Seero, there are things in your post that I disagree with and things that are flat out wrong.
You don't need to drop a lot of cash to get a better than stock cooler. XIGMATEK has several $30 or less options that are top notch.
Where I live an over-clock without a good cooler will burn your CPU out in the summer. Not to mention having a decent cooler prolongs the life of the CPU when you push them hard. I can understand lapping the bottom of the CPU cooler. I see no reason to lap a CPU & void the warranty for a very slight bump in performance that could also be had with an extra $10-$15 invested in a cooler.
The warranty doesnt even matter as overclocking will void your warranty anyways, so who cares if you lap or not you still have no warranty if you overclock.
Odd but interesting thread. What I'm curious about is lapping in terms of an industrial and financial sense. Take the nickel plating on cpu spreaders. Putting this coating on obviously costs Intel and AMD money, and if it is detrimental to performance, why would they do it?
