Label Maker for CD/DVD's?
epson r200 or higher with a continuous ink fill system....
i have printed about 3000 discs off mine... the ink system will save you a lot of money
+1. Taiyo-Yuden hub printable media is 40 cents (usd) per DVD (8x +R).
The issue with labels and DVDs is that a slightly off-center label will cause the disc to wobble enough to create read errors. Read errors can reduce the playback performance. Plus, no peel and stick annoyance. But the negative is that the label "stamper" is fun to play with 😉
I've tried several applicators, and frankly, I haven't found them any better than just buying labels, running them through my inkjet, and carefully applying them by hand. It works.
