i got a Koolance PC2-C case with their CPu-100 water block and my cpu appears to be running hot. at idle it is around 93-96 and under load it is well over a hundred. is this normal for a p4 socket 423 cpu @ 1.5ghz. it is not overclocked at the moment. i wanted to go water cooling because of the low noise, but when the fans are at 100% it is quite noisy. has anyone had any similar experiences or advice here? i used the arctic silver 3 compound with no luck. the hoses don't appear to be bent and both pumps are working fine to my knowledge. an email to webmaster@furad.com would be greatly appreciated.
THANX ALOT!!!
THANX ALOT!!!
