Konica Minolta unveils cheaper digital SLR camera with anti-shake built into the body
vi edit
62,484
8,345
Is it Konica or Fuji that has Nikon lens mounts for their SLR's?
NFS4
48
Originally posted by: Triumph
Sounds like the DRebel will be cheaper with kit lense.
Well, I would suspect that in-body IS isn't that cheap for an SLR ;)
NTB
5,179
Originally posted by: NFS4
Originally posted by: chimmytime
Do all DSLR use compact flash for storage? no SD?
Nikon D50 uses SD
and I believe some of Canon's higher-end DSLRs can use both CF and SD. I know there's at least one camera that can do that...
EDIT: and you can buy and SD-->CF adaptor to use SD cards in CF-only cameras, as well.
Nate
BaboonGuy
4,125
Don't see why anyone would choose this over Nikon or Canon as the lens selection is a lot more limited. I could be wrong about that but I doubt it.
NTB
5,179
a) you already have an investment in a film KM system. all you need is the body
b ) all other things being equal, this might be cheaper in the long run if you had planned on investing in IS glass for another system. The IS here is *in the camera*, so every lens you buy is autmatically image stabilized :)
Nate
Jawo
4,125
CF currently offers cards up to 8 GB, SD, I think is only at 4GB....When your taking 8 meg TIFF files...the space is consumed VERY quickly....therefore need the largest cards available...even if they are bloody expensive
NTB
5,179
I believe CF has a speed edge too, but I might be wrong. Personally, the gargantuan cards don't appeal to me much - the whole "all my eggs in one basket" thing. Until the files start getting considerably larger, I think I'll stick with 512MB and 1GB cards.
Then again, I'm not shooting for a living, so switching cards and possibly missing something doesn't bother me too much, either.
Nate
chimmytime
702
I guess my actual concern is, do camera using CF still slow? There was a huge difference when i moved to SD, but this was years ago so i don't know if the technology has caught up.
NTB
5,179
This depends on the card you use, and possibly the camera. I'm not sure of the exact differences between a cardslot on an SLR camera vs. one on a point-and-shoot, but the difference between a high-speed card (say a Sandisk Ultra or Extreme) vs. a standard - and cheaper - 4x or so card can be quite noticeable. I've tested it myself.
Nate
DBL
2,637
I love the idea of using larger lcd's but they really have to start increasing the pixel count. Otherwise, it just doesn't seem like a very attractive feature to me.
