Know of any uses for solid concrete cylinders?
bonkers325
13,076
do you work for the DOT by any chance?
collect enough until you can build a pyramid, then drive through it
Excelsior
19,047
18
Nope, a "small" private engineering company.
To answer some of the other questions...as of now I have about 10 behind the building, but...Id say by the end of the summer I could have close to 100..its hard to say.
Also, they are solid all the way through...just incase anyone was confused.
Nebor
29,582
12
Sell them to an American car manufacturer. I think they still use iron and concrete along with their pushrods. :p
kranky
156
Cut them in half lengthwise, and surprise your neighbors with some new speed bumps.
ManyBeers
2,519
Originally posted by: Excelsior
Part of my job involves breaking concrete cylinders to see how many PSI they can handle and with each set of cylinders, one is a reserve. If the first four pass then the reserve is usually thrown away. However, this seems a bit wasteful to me, so I have started saving them in case I could figure out a use for them.
Now...can anyone think of something I could use them for? They are pretty strong (most can handle 3000+ PSI and for the most part, untouched.
Specs: 1 foot high/long
6 inches in diameter.
It's not a waste to throw away concrete cylinders that are 1 foot long by 6 inches in diameter.
pontifex
43,804
46
Originally posted by: DEMO24
Im refraining from commenting what i want to say, but its so very hard :p
i'm surprised it took this long for someone to say something like that.
Excelsior
19,047
18
I guess..I just hate throwing stuff away.
Jzero
18,834
Originally posted by: Jzero
How much do they weigh? They could make workable "poor man's" curling stones.
My estimation is 15-22 or so...they vary a bit.
You would have to stick two together since they should be 40-44lbs.
skyking
22,778
5,941
build some fine walls/fences out of them. that is what all the dirt breakers I know do with them:)
Grade out a trench, and lay the first course down. Fill in the gaps with cheap mix, and repeat.
WildHorse
5,006
Large CHESS pieces !!!!
Maybe get with one of those gypsy-type people that float around to the crafts fairs, who could make some kind of sleeve fitted over the stump, to fashion the individual pieces. Patio chess!
Specop 007
9,454
If your located near Kansas City, I'd happily take them off your hands.
I just dont want to pay to ship them, that'd cost an arm and a leg.
