- Dec 25, 2008
- 9,147
- 1,329
- 126
Some more comments on kitguru about the GTX 590 VRMs and related issues are up.
Their earlier posting related to the 590s receiving updated BIOS', http://www.kitguru.net/components/g...-gtx590-bios-rushed-out-to-repair-reputation/, which some felt was false, while not 100% dead on, did turn out to have the right of the situation with an updated BIOS being releaed shortly after:
http://support.asus.com/Download.aspx?SLanguage=en&m=ENGTX590+Series&p=9&s=2
http://techreport.com/discussions.x/20711
Here is Kitguru's latest blurb on GTX 590 VRMs and their characteristics:
http://www.kitguru.net/components/graphic-cards/carl/nvidia-come-under-fire-for-poor-gtx590-design/
'...KitGuru reported before that respected website Hardware.fr analysed the GTX590 with a thermograph.
Their GTX590 testing showed a reading of around 112c under load. Since we reported on this, our readers have been filling our inbox with comments and views on the matter. Some partners have been updating card bioses to supposedly help with power delivery however the main issue is apparently down to a poor VRM design. The very high temperatures are due to the VRMs being underspecified. Each of the GPU/IMC phases has 35A each, and only four phases per GPU, with one phase for the IMC.
With the DrMOS chips being operated at close to peak forward current rating with a high duty cycle, this is part of the reason of the stress related failures. At very high load levels the DrMOS chips can become very inefficient as they are optimised for efficiency at low loads. Some claim they shouldnt be used for VRMs for high power electronics in the first place. This inefficiency is adding more wasted heat into the scenario. Nvidia have placed them right under the fans dead spot too which doesnt help with cooling.
Why wasnt this a problem with the GTX580? Well this card was complimented with 6+2 power phases and the design is dramatically different. It looks as if the bios changes might not be the cure, and many people will be best waiting on third party custom designs from companies such as ASUS which will rectify the poor design aspects of the latest Nvidia flagship card....'
In the lab501.ro review where they had a 590 fail, they also comment on the quality of the 590's VRMs here:
http://translate.google.ca/translat...dia-geforce-gtx-590-studiu-de-overclocking/12
While I cannot find a detailed layout of the 590 PCB, are these below examples of 590s that have failed, all with the same component burning up; giving an example of VRM failure ? The component that has caused the 590 to fail in these three separate examples is not a VRM. The 590s VRMs are in this first picture, they are the two strips of five larger cube type components and below that are three examples of GTX 590s that failed with different components on the PCB burning up.
Could the failure of VRMS cause these other smaller components to exhibit failure and ignite, or are these smaller components something independent to the VRMs. And can anyone identify what these smaller components that burned are ? Resistors ?
The 590 VRMs, the large cubelike components in a series of five on the top and bottom
Three examples of the same components failing on three different gtx 590s, note these are not the VRMs:
http://translate.google.com/transla...ulletin/showpost.php?p=3960849&postcount=352'
http://forums.overclockers.co.uk/showpost.php?p=18781867&postcount=140
http://img231.imageshack.us/img231/2055/sdsdu.jpg
Oddly with the gtx 590 that failed at Techpowerup http://www.techpowerup.com/reviews/ASUS/GeForce_GTX_590/26.html he identifies a resistor
and then a MOSFET that burned out
These are neither the VRMS or the smaller components that burned out in these other photos.
Unfortunately the other review sites that had 590s burn out did not post pictures of where the failure occured on the PCB, ie: the sweclockers youtube video, you just see the spark and then the system crash: http://www.youtube.com/watch?v=sRo-1VFMcbc
For those that understand this better, is it possible for VRMs pushed beyond spec due to overclocking to cause these separate components to have failed or would it be isolated to the VRMs ?
Per this hardocp review http://hardocp.com/article/2011/04/03/asus_geforce_gtx_590_overclocking_followup power management functions are now effective on the 590 via drivers, 267.71 and this prevents the 590 from burning out and shows examples of the card throttling when voltage is adjusted.
