Kitchen sink won't drain
Eilek
Someone posted this on another thread and this is all of my symptoms exactly but they never said how or what to do to fix it.
Do you experience gurgling in the drain or other house drains? Or for instance you flush a toilet and other drains in the house gurgle? Any siphoning of traps dry (typically you would notice a stink from a dry trap allowing gases to enter the house?)
If you fill the sink with water and let the drain out, it drains slowly? If you begin to unscrew the cleaout threaded plug, can you hear air rushing past the plug? Can you start/stop the drainage by placing your palm over the open cleanout (in effect sealing it)? Does air want to rush in or out of the cleanout when open
