Kaido
Is this thread only for smaller kitchen appliances ? I would like to inquire aabout major appliances, namely full size electric induction cooktops. seriously considering getting one and would like to know if any members here have one and if they like it.
All appliances are welcome!
induction is the way to go if you don't have gas available. We have gas, but have used induction and its much better than halogen or resistive elements. look for high end stuff on craigslist or similar, we buy our majors used and have gotten great, high end stuff that is barely used.
So, my history:
1. I started out on electric coils (standard oven with range top). Messy, slow, not a fan. Pain to clean up!
2. I upgraded to a cheap electric (not induction!) flat-top glass oven. Not a fan for a few reasons
1) The glass gets messy & is a pain to clean, so it requires constant maintenance to keep it looking nice.
2) The heat spreads throughout the glass, and the glass stays hot for a long time, both of which I don't care for.
3) It takes forever to heat up.
3. I then purchased an 1800-watt induction portable cooktop (hotplate):
1) The current model goes for about $160 on Amazon.
2) You can adjust the wattage as required (600, 900, 1200, and 1800 watts), like if you have a camper or something.
3) You can specifically adjust the temperature in 5-degree increments, with a max temp of 575F.
4) You can take it outside, which is what I use this model for - I cook a lot of food using sous-vide & searing stuff like steaks & burgers is a smokey process.
5) It requires magnet-friendly cookware; not all pots & skillets will work on it.
6) It heats up stupid quick.
4. I then purchased a 1500-watt "smart" induction hotplate:
1) The Tasty OneTop goes for $150 online.
2) Max temp of 450F (not the best for searing, but does an OK job)
3) It connects via Bluetooth to your phone, for precise temperature control
4) It has a temperature sensor in the middle of the cooktop, for precision control
5) It also has a plug-in probe, so you can precisely cook meat, or do sous-vide, or heat up oil to exactly the temperature you want
6) I use this one indoors, for everything I'd normally use my stovetop for, as well as for oil-frying
Personally, I rarely use more than one burner at a time in my cooking, so I have shifted all of my pot & pan use to the induction cooktops. I use the 1800w model outdoors for searing & the "smart" cooktop indoors for frying & skillet/pot-cooking. If I were to remodel my kitchen, I would do the following:
1) Remove the single electric oven & flat-top range
2) Put in dual electric wall ovens (550F max with self-cleaning)
3) Put an external ventilation system overhead of where the range was before
4) Replace that area with countertop (Dekton!)
5) Add some dedicated 20-amp circuits
6) Just use my appliances & plug-in induction cooktops
That's a pretty non-standard setup, but I'd like that a lot more than what's currently available.
@echo4747 - looping back to your question:
1. Induction is awesome
2. The prices have gotten more reasonable (Home Depot has stove/induction-top combo units in the $900 range, where they were previously $2,000 to $3.5k)
3. The glass flat-top requires regular maintenance to keep looking good
4. Make sure you have induction-compatible cookware (or else buy an induction disk)
My wife's family (Italian) prefers cooking on gas. I don't mind gas, I just find it messier (burners) & have found induction to be equally good in most respects. The one exception is when I'm doing indoor wok cooking, in which case I use a portable sub-$40 butane burner, which is also excellent to have on-hand for when there's a power outage:
https://www.amazon.com/Iwatani-Corporation-America-ZA-3HP-Portable/dp/B006H42TVG
So that's my approach...I use my Tasty OneTop indoors, plus a butane portable burner, and really love that setup. If I had to buy a replacement combo unit today, I'd probably spring for this $900 Frigidaire unit:
https://www.homedepot.com/p/Frigida...ge-Proof-Stainless-Steel-FGIF3036TF/302580321
If I were going to spring for an amazing unit, I'd go with this Samsung model, which has the dual-oven technology, plus the cool Virtual Flame tech on the induction burners: (ignore MSRP, it's a good grand cheaper online)
https://www.samsung.com/us/home-app...tion-range-with-flex-duo-oven-ne58h9970ws-aa/
