Kingston 2GB CompactFlash Elite Pro $122 AR
c627627
1,155
The digital cameras that take 256MB cards like Canon A60, they're also compatible with 1GB & 2GB cards or no?
czech09
8,990
Bump Becauseof2gigsholysh1twhatthefvckareyougoingtodowithallthatIhavea128mbcardandcantseemtofillthatsh1tup
c627627
1,155
I'll take thisone.
1. You're at Mardi Gras
2. You're without your camcorder.
3. Boobage everywhere and you need to send a video report back from the front.
Hello! A lot more video footage (and consequently 15 times more boobage) can fit on 2GB.
imported_SNP
151
c627627, normally, if the memory card is more expensive than the camera, then it either won't work or not worth it, for the camera that is :)
anyway, the 1GB is plenty for A60
c627627
1,155
Are both these compatible with cameras that take 128MB cards? What's the limit anyway?
("limit" as in Windows 9x/Me having a 137 GB "limit" without PCI cards...)
:) hah, so if the hard drive is more expensive than the system, it's incompatible? :)
vanderStoep
333
Yes.
Compact flash (CF) has a lot of the read and write hardware on the disc instead like the other mediaformats (SD, MS, XD, etc) which has more hardware on the reader (camera). The effect of this is that old CF readers are compatible with the newest CF media whilst the other formats sometimes need firmware updates or could be uncompatible.
