On Thursay morning I decided to see just how my 5850 would overclock and be stable. I upped the core to 1.275v and cranked up the fan. Was using the 10.3a drivers at the time. Well I'll just say I crashed CCC one too many times I guess. On bootup win7 does the animation and during the next faze which would be login screen just comes up black screen with a frozen mouse pointer. Safe mode s no problem at all but doesn't give much options. Drvers won't remove gives an unable to in safe mode mesage. Drivers won't install in safe mode also error of unable to start detection process error.
I tried changing to standard VGA driver and booting into windows thing. Does fine and let's me remove the drivers then. Used driver sweeper then also which seems to work too. But once drvers are loaded same thing on reboot again.
Hmm....I think maybe I nuked my card and do fresh install on spare drive. Load drivers again and it works fine. Set card to my overclock again works fine. Stress test the card and it works fine. Figure the cars is fine. Max is 1000/1300 but I'll need water block as 70% fan speed is insane
Any ideas how to fix the driver issue? Not like I couldn't just reload my SSD but kinda would like to fix it if possible.
Thanks,
Ken
Thanks,
Ken
