killdisk problem
pyroazmb
hello. i have a computer that i wanted to wipe clean and reinstall windows 7. after i ran killdisk and it completed, i then put in the windows 7 cd. the computer did not load up and an error came up that says "reboot and select proper boot device or insert boot media in selected boot device and press a key" when i put killdisk back in it says that my drives are allocated so i figure that the computer is not detecting my drives? can anyone please help me? thank you in advance!
pcgeek11
22,232
4,935
Set it to boot from the CD/DVD Drive in the BIOS and watch for the prompt " press any key to boot from CD " and press any key on the keyboard when you see this.
pyroazmb
what key do i have to push to open up the BIOS? because when i start the computer it doesnt even give me a chance to push a key before it goes to a black screen that says the error: "reboot and select proper boot device or insert boot media in selected boot device and press a key"
pcgeek11
22,232
4,935
Do you have a motherboard manual? What kind of PC is it?
Try these
Del key
F10 key
F2 key
Esc key
pyroazmb
ok so it was F1..its an HP computer. im now in my boot device priority and the 1st one is the floppy drive and i also have a lite on drive and a wdc drive..which one should be first?
dac7nco
756
Lite On, WDC, Floppy(!), in that order.
