Key Stuck in Ignition
sime0n
29
Hey ya'll
I just drove home today pulled into my garage and accidentally tried to pull the key out while the engine was still on. After turning the engine off i still can't pull they key out. It's stuck in the 1 (acessory) position. I can still turn the engine on but i just can't remove the key.
i drive a honda accord 2000 LX with automatic transmission
here's the thread on http://www.houston-imports.com/forums/showthread.php?t=304159
but i'm scared they might just be playing me for being a n00b
Rastus
4,704
When the pins inside the lock mechanism get wore out, that is one of the things that happens. It happened to me once and a locksmith had to come and rekey the whole car. Costed about $120.
EvilYoda
21,198
9
Try adjusting your shifter...happened to me once in the GTO, but not because I tried to pull the key out prematurely. Just try moving the shifter, steering wheel all while fiddling with the key. Don't be too forceful though.
Dec 10, 2005
29,740
15,344
Originally posted by: LiquidSun
At least you won't have to worry about losing your keys.
Careful, you don't want to be making too many posts, otherwise that ppd count might jump up to a .02 ;)
bctbct
4,868
Same thing kept happening to me. I went to a locksmith and he replaced the ignition in the parking lot....15 min and $45
dionx
3,500
i have the same car you have, and i thought my key got stuck. i just forgot to put the car into P and it was stuck in N or D when i turned the car off. make sure it's not something as simple as that.
Tiamat
14,068
:laugh:
DainBramaged
23,454
41
haha...nice catch
crumpet19
2,189
If you've got the time and want to save some money...
Go to the parts store and pick up a chilton manual and a new ignition lock cylinder -this should also come with a key ($6 part). Also see if they'll let you rent a lock plate puller (tool that helps you pull the steering column apart.
g/l
Zenmervolt
Elite member
Oct 22, 2000
24,514
44
Originally posted by: sime0n
transmissions in P, guess i'll get a mechanic to look at it tomorrow.
Take it out of park and then kind of "slam" it into Park. That will make sure that it's registered.
ZV
sime0n
29
i'm not sure what i'm gonna do about this..it seems really expensive to go to a locksmith or even a mechanic. the honda dealership service said 86 dollars just for a diagnostic, most locksmiths around here seem to be charging 100+ just to remove the key.
MaDDinGO
379
In most honda/acura's you have to push the key in, then turn to get it out of the ignition.. did you try that?
GeneValgene
3,884
did you try slamming the shifter into park? did you push in the key before rotating and pulling it out?
Rogeee
622
Follow this procedure exactly ;
Start the vehicle
Run the shifter through all the ranges
Apply brake and pot shifter in park
Push key inwards into cylinder and hold it there
Shut off ignition while still pushing inwards
Wiggle ignition back and forth in Off postion while attempting to remove key
Do this at least five times
If this does not work, P.M. me.
Scarpozzi
26,392
1,780
Try pushing the key in further and try turning the wheel to make sure your steering wheel isn't locked.
Soapy Bones
397
Is the key that is stuck in the ignition a copied key or an original?
At my hardware store we have stopped making copied automotive keys for Honda and Toyota I believe because we have had more than one instance where the key gets stuck in the ignition. I'm not sure if that is what the situation is with you but it sounds more commonplace than I would have expected.
Synth3t1c
293
slam it in park and move the wheel around a bit while having the foot on the break
same experiecne here, 96 accord though
