First time posting here, so don't flame me guys.
First off, I have NOT OC'ed anything yet. And just about every setting is at default settings/speeds. And I consider myself a pretty computer savvy guy. I just did an upgrade on my main gaming box, and I bought:
ASUS K8V Deluxe
Athlon 64 3200+
OCZ EL 512mb PC3200 (DDR400)
and a nice new case... (not aluminum 🙁 ) anyway. And I have my ATI Radeon 9700 Pro i got awhile back. And was running fine in my old P3 1Ghz box at 4xAGP. (new box using an Enermax 300watt PSU by the way...)
I did a fresh install of Windows 2000 Pro SP4 on the new Box. Drivers: Catalyst 4.3's, Hyperion 4in1 4.51 And i updated the BIOS to 1005. Everything was fine, till I started up 3DMark 03 and tried to bench it. Somewhere half-way thru the first test the video locked up, I rebooted. I tried benching again and it happened again roughly around the same spot, this time VPU recover worked, and I was back in the desktop. I thought maybe it was limited to just 3DMark 03, but I threw on FarCry, and the screen locked up again a few mins in. Same thing happened with 3DMark 2001SE. There were no visual artifacts or anything of the sort before the lock-ups... But i was running GTA: Vice City fine for 2 hours with no lockups... so i'm at a loss.
I thought it was maybe the drivers, tryed 4.2's and then 4.4's and tryed some older 4in1's on the ASUS CD, still the same thing. Everything is running cool, except my Radeon which was pretty hot... so i used powerstrip to underclock it to 270/280 and i was able to bench with 3DMark 2001SE all the way thru? And was able to play FarCry several times without any lockups till it happened even at the lower speeds.
Earlier I tried setting the AGP in the BIOS to 4x only and at stock speeds i was able to run the full bench in 3DMark 2001SE. (18K score 🙂 ) And play FarCry and benched again... and all was fine. Then i tried 3DMark 03 and during the bench at CPU Test 1 the video locked up again. but VPU recover came in and got me back on my feet. During that session i got the temps on my card, the backside of the core was at 61C/141F !! and worse the ram was 69C/156F ... the card was SERIOUSLY HOT. but the bench finished and i got a mild score. (5200 :frown: ) I ran 3dMark 03 again and it locked up in the first 2000 frames of test 1.
So i don't know if my Radeon is screwed up?
Or if my Radeon and K8T800 Chipset don't want to play nice?
Is the card getting too much voltage? pushing up the wattage making it overheat?
Not enough power?
Something with Windows 2000 causing this?
So does anyone have any ideas? any suggestions? or knows what the heck is going on? I'd like to think i could get this solved without having to call up ATI and have to deal with the customer service! and or getting a brand new video card... 🙁
Thanks, Alex.
ASUS K8V Deluxe
Athlon 64 3200+
Not enough power?
Thanks, Alex.
