phishflavr
This is my main problem mapped out as best as possible using a KVT266 Pro2-RU MB.
Everything in the bios is fine.. bios is version 3.2.. except for when I go to the hardware profile section and it will show me the current temp and RPM but I have no options to pick anything and I can't move around.. So in essence it freezes up and I can't go back. Now.. when I clear the bios or try to make a bootable floopy and put it on the computer... it will not bootup.. so I can't even try to flash the bios. When I take the disk out of the comp and put it back in my laptop it says that my disk needs to be formatted.. so I'm running into a bunch of problems.. if this helps you understand the problem it would be great.. hmmm
