Here are some of my thoughts on the original K7S5A, mostly a cut and paste from an earlier post:
About a year ago, I built my first PC with a K7S5A + 950 MHz Duron combo that I bought from Fry's ($80 for the combo). It has worked great from the start but some people have run into problems (Lost CMOS, Data Corruption, Cold Start Problems, etc.)
I'm using pretty generic PNY PC133 SDRAM in my set-up so, at least in my case, top quality memory was not required.
Some people suspect that many, if not all, K7S5A problems can be traced to inexperienced builders. But there have been *very* experienced builders using top notch components that have *still* run into problems with this board. I base this perception on reading tons of posts in several K7S5A forums for over a year (amdmb.com ECS forum, Mr. Athlon's K7S5A forum and the OCWorkbench.com ECS forum.)
For some, problems can not be corrected through the use, say, of a high quality power supply. While a quality power supply is always a good idea, I feel that this has been oversold as a cause of multiple K7S5A related ills, especially on the OCWorkbench.com ECS forum. (FWIW, I did use a decent Enlight 340 Watt power supply in my PC. It works fine.)
I personally suspect that not all K7S5A motherboards are the same and some work better than others. In other words, there may be quality control problems. Whether or not the percentage of K7S5As experiencing problems is any different that other motherboards is difficult to say. Again, my board works great.
Because there may be board to board variations, I wouldn't recommend buying a K7S5A through an online vendor if you find it locally for a reasonable cost. That's one reason that I bought my K7S5A from Fry's instead of from Newegg.com or mwave.com. I had read enough problem reports that I didn't want to risk the time and hassle of a mail order return and exchange. (If an online purchase is your best option, I don't think you could go wrong with either Newegg or mwave.)
If you do buy from a Fry's, here's a tip for selecting a motherboard. Look for a sealed box without the "Fry's returned item" sticker on it. Sure, most of these are probably fine but why take a chance?
The Burbank California Fry's has a tendency to place the stickered boxes within easy reach while the brand new boxes can be harder to find.
Here are some of the more helpful links for the K7S5A:
Mr. Athlon K7S5A Problem Fix Guide
Mr. Athlon K7S5A Forums
amdmb.com ECS Forum
Bob
