K7m with ata100 problem
fastvideo
932
anyone tried to put ata100 hd with k7m? i got a beeping sound when i use it with ata100 hd. have tried to put it on a fasttrak 100 pci alone, same problem.
any help???
XMan
49
My K7M is beep happy, too . . . does it not boot, period? It just won't turn over and beeps continuously? If the video doesn't post, try switching power plugs . . . the one you have plugged into the drive could be bad, perhaps?
fastvideo
932
no, i put the same connector and power plug back to my ata66 hd, it works .
on fasttrak 100, ata 100 alone, beeps, 1 ata66 and 1 ata100 ok.
jonnyGURU
Moderator <BR> Power Supplies
Moderator
Oct 30, 1999
11,815
104
You have tried to put it on a fasttrak 100 pci alone, same problem? Weird!
Pull your other PCI cards out and try it.
fastvideo
932
yes, ata100 alone beeps even with fasttrak 100, if you think there might be a bad contact, why it works with 1 ata/66 and 1 ata100???
