Here's my system:
AMD Athlon 64 3000+ 939
ASUS A8V Deluxe R2
PDP system Patriot memory 2x512mb pc-3200 dual channel 2-3-2-5
WD 80G SATA (x2)
IBM IDE 80G
ASUS Ge Force 32mb. from previous system.
ASUS wifi home card
Antec Sonata with True 380
I had my system up and running for about a week now and in order to get the network to work, I had to reinstall sp1(i had installed 2000 prior to xp) and then sp2. However, right after installing sp2 it started to crash. I'd get blue screen right after desktop come up. Thinking perhaps it's the memory I tried removing one stick of memory and tried them independently, but the problem was still there.
Downloaded from another machine OCZ memtest86 and ran through test7 and found no error.
At time, when rebooting I sometimes got Overclocking failed when I didn't overclock at all I had it at 'Auto'. I tried setting it in 'Standard', but same blue screen. The only think I can think of doing is try another brand of memory, but I'm not sure if that's the problem.
Could the hard drive be bad? I did notice it doing chkdsk once before when booting by itself when things were still fine.
HELP
ASUS A8V Deluxe R2
WD 80G SATA (x2)
IBM IDE 80G
ASUS wifi home card
HELP
