WdnUlik2no
Originally posted by: JonnyBlaze
post a comparison linkOriginally posted by: WdnUlik2no
Wow, this score seems pretty low,
My 3dmark 2005 score was 2471.
http://service.futuremark.com/compare?3dm05=852090
Originally posted by: Dman877
Does this happen in any other games? I don't think it's the 9800 Pro, those 3dmark scores are spot on with what you should score. You should be able to play at 10x7 with medium or maybe even high quality.
Originally posted by: PrayForDeath
I have a 9800Pro on my other machine. My score in 3DMark 05 is close to yours, so there's no problem there.
Doom 3 runs fine on my 9800Pro at 1152x864 noAA/16AF High Quality, the FPS never goes below 40, and the card is not overclocked. I mean that your card is capable of running Doom 3 pretty well.
What's your OS? Have you installed all the windows updates? Do you have the latest motherboard drivers? (this is crucial), if not, head to nVidia's website and download the latest nForce package. And do you have any programs running in the background while you're playing? How many process do you have when and what's the memory usage when on desktop (idle)? Try to turn off everything (including anti virus) using task manager or whatever then play the game. Try even to update your mobo's BIOS since yours is more than a year old I assume.
Try playing other games and see if you get the same problem. Try to install the latest patch for Doom 3.
Usually, if a video card overheats, it displays artifacts or crashes, but it doesn't slow down.
Scan for virii and spyware.
Look at the Catalyst settings and see if something odd's turned on. Make sure AA/AF are turned off as well as vertical sync.
Check the CPU frequency in the BIOS and see if it's setup as it should be (some motherboards don't recognize the native CPU speed, so you should set it manually). Check your memory's frequency (DDR400) and timings and latencies. Check the CPU temperature and voltage and see if something's odd there.
What PSU do you have? Check the 12V and other lines' voltages and see if they're stable.
Finally, if all doesn't help, install a fresh windows and see if that helps.
That's all I can think of at the moment. It too early to give up 😉
Good luck 🙂
edit: by the way, 1Gb of RAM is more than enough for Doom 3. So dont' worry about that. And try to reinstall Doom 3 if the problem's only in this game.
Originally posted by: KruptosAngelos
ATI drivers don't have any bloatware 😕
All it installs is the driver and the control panel that controls the driver, there's nothing else.
:|Locked up AGAIN:|
Now going to update BIOS....
Update: BIOS update succesfull
Now going apply the doom 3 patch.
:|Locked up AGAIN:|
Good luck :beer:
There could be a problem with the game files that causes a memory leak which adds up to make the game choppy after 30 minutes, that's why reinstalling the game might be a good idea if the problem presists.
