Originally posted by: toyota
its not just the card you will have to worry about. the card runs atleast 25 degrees C hotter than a 7600gt. a 7600gt is already a pretty warm card. ALL your components will be affected.Originally posted by: blckgrffn
My case has a side fan that blows directly over the video card. I am not too worried
If it burns out, that is what a good warranty is for
Nat
Whatever manHeat of the card doesn't matter so much as net energy dissaption of the card. 32W is half as much as a 7600GT no matter how hot the actual card gets.
well 90 degees celcius is hot no matter how you look at it and that was on a stock 7600gs at 400/800. yours is gonna make toast at 500/900.
i dont think you get it. who cares how it performs if its running at 90 degrees celcius.Originally posted by: blckgrffn
Nat
I don't think you get it, but don't think about it too hard
AkumaX, I am not too worried about it. The x1600xt is a different animal, with lot louder cooling solution. I guess we'll see when more benches come out. As long as it is even with the xt at the games it excels at and better at most other games where raw fill rate matters, I am fine with that.
As long as it plays guild wars full out, that is all I really care about right now![]()
i can read. i was looking at the hottest temps. no other video card is anywhere near that hot no matter what part you are looking at. if you use some common sense then you would know those temps are under load not idle. again those are the highest temps i have ever seen for any video card. the one he is getting is overclocked so it will be even hotter.Originally posted by: Cookie Monster
You are reading the graph totally wrong. The GPU ISNT at 90C at load, the power transistors are.
They dont mention if its load or at idle but i would think that the passively cooling on the reference 7600GS boards NV showed indicates that the GS doesnt overheat.
Wait for more reviews.
