- Sep 13, 2001
- 53,543
- 6,368
- 126
I just installed this door and it's my first storm door. This is the exact door I installed.
I had a couple questions.
1. I feel like the tube looking part on the bottom of the door that helps pull the door closed and slows it down (forget the name of the part) is louder than it should be. It almost makes a little clicking noise as it opens. Is that normal? My wife didn't think it was too loud.
2. The bottom half of the door when shut is noticeably not as "tight" as the top half of the door. There is some wiggle on the bottom like 1/4th of the door when it's shut. I can pull the handle tighter to pull it closer and you can see it gets tighter as I am pulling it. The top is as tight as could be. I am wondering too if when I installed the door I could have bent it somehow because at one point it tells you to just "pull" the door open with force, and I tried and the bottom was coming off but not where the latch is. I ended up having to google it and the guy in the video literally just pulls it hard and it opens, but mine didn't open that easily. I'm wondering if it's something I did or just the door frame, but wondering if I can do anything about it.
3. This is kind of in relation to #2, but when I just let it close on it's own, it slowly closes, than like a couple inches within the door latching it just kind of "gives" and closes fast at the last part. It's a bit loud and sounds like it's slamming, but I think it's louder because the bottom 1/4th of the door kind of bounces back/forth real quick in that area that has some give and isn't tight. Is there anyway to make it so it just slowly shuts to the latch? I did adjust the screw that changes speeds, but that seemed to adjust the speed the door shuts UNTIL it gets to that last few inches, then it just slams shut.
Think that is all. This is my first time ever with a storm door so just wondering about these.
Andersen 36 in. x 80 in. 3000 Series White Left-Hand/Outswing Fullview Easy Install Aluminum Storm Door H3FEL36WH - The Home Depot
The Andersen 3000 Series Fullview Storm Door is one of our most popular seasonal ventilation storm door offering you a wide variety of features and options. This full light style storm door has glass from top to bottom to maximize your views, along with our most convenient features, low...
www.homedepot.com
