I just finished this build and wanted you guys to check out my benchmarks and temps to see if they're what you would expect with this setup. I use this rig mostly for gaming.
Before
After
Specs
Intel Q9300 @ 2.5 GHz
Xigmatek SD-HDT964 92mm rifle HSF (applied with AS 5)
Gigabyte GA-EP45-UD3R
Patriot Viper 4 GB (2 X 2GB) PC8500 1066 5-5-5-15
2 X WD Caviar Black 640GB (OS on one, Games on another)
GTX 260 core 216 65nm @ 576/999/1242
Corsair 650TX PSU
LG 20X DVD-R
5 X 120mm fans (2 intake, 3 exhaust)
80mm fan on back side of CPU
Windows Vista Business 64-bit
All in a Cooler Master CM 690
3DMark06: 12974
SM2.0: 5K
HDR/SM3.0: 6K
CPU: 3693
3DMark Vantage: P11410
GPU: 9338
CPU: 34140
PCMark Vantage
PCMarks: 5223
Memories Suite: 4297
TV and Movies Suite: 1283
Gaming Suite: 5446
Music Suite: 4083
Communications Suite: 4996
Productivity Suite: 4626
HDD Test Suite: 3502
HD Tune Pro
OS Drive
Min: 44.7
Max: 114.6
Average: 88.8
Access time: 12.1
Burst rate: 131
CPU usage: 2.9
Games Drive
Min: 57.2
Max: 113.8
Average: 92.9
Access time: 12.3
Burst rate: 139.2
CPU usage: 3.3
Temps (idle/load) (15 minutes of ATI tool artifact scanning and Prime95 together)
System: 35/42
CPU: 19/38
Core 1: 44/58
Core 2: 44/56
Core 3: 46/59
Core 4: 44/55
GPU: 41/59
HDD 1: 32/32
HDD 2: 34/34
Everything look normal? This is my first time with Intel and Vista, any suggestions for tweaking/optimization?
Before
After
Specs
Corsair 650TX PSU
LG 20X DVD-R
3DMark06: 12974
SM2.0: 5K
HDR/SM3.0: 6K
CPU: 3693
GPU: 9338
CPU: 34140
PCMark Vantage
PCMarks: 5223
Gaming Suite: 5446
Music Suite: 4083
HD Tune Pro
OS Drive
Min: 44.7
Max: 114.6
Average: 88.8
Access time: 12.1
Burst rate: 131
CPU usage: 2.9
Games Drive
Min: 57.2
Max: 113.8
Average: 92.9
Access time: 12.3
Burst rate: 139.2
CPU usage: 3.3
System: 35/42
CPU: 19/38
Core 1: 44/58
Core 2: 44/56
Core 3: 46/59
Core 4: 44/55
GPU: 41/59
HDD 1: 32/32
HDD 2: 34/34
