Originally posted by: jtusa
2002 Maxima SE 6-speed. Nice car, drives great. I'm picking it up pretty quick, but the whole stop to start thing is messing with me. Let's just say the ignition and starter are being thoroughly tested. I'm not even close to mastering the downshift yet either. Those have been the two hardest things.
Although I'm already starting to agree with the advocates of manual transmissions, they can be lots of fun and it isn't as much of a hassle as I thought it'd be. I'm sure I'll think that even more once I get the hang of it.
Dont try to launch perfectly from the start. Youre a newb, so you have to launch like a noob - youll get better at it before long.
When youre stopped, just let the clutch out a bit until it feel it "bite" - thats the magic grab point. Push the clutch back in, Rev it up a bit, slowly let it go through that point, youll begin moving, then slowly give it more gas and keep going. You have to learn how not to hesitate. For now, give it way more rpm, which is kind of like a stall buffer. Once you get the hang of it, you can do it fast and naturally.
Let off the clutch slowly in first, medium in second, and fast in third, and as fast as youd like between 4, 5 and 6.
And learn to rev-match when you downshift. Think the revving during your shift as a power boost youre saving up - the lower down you go, the more you need to rev, because youre going to probably be accelerating that much faster.
I can definitely say the shifter and clutch on my celica is a pain in the ass most of the time. The clutch is like a light switch, and the shifter is tight. But when I'm going all out, it couldnt be more perfect, I can do 1-2 in probably half a second or less. It demands precision or else it wont even shift right.
